Wheel fitment?
Im considering 15"x8" Magnum500 wheels with 225/50/15" BFGoodrich G-Force Sport tires. Is that pushing the limit on how wide a tire I can put on the 8"? Tirerack's fitment chart says 6"-8" wheels...
8" is OK up to about a 245-width tire, maybe even OK for a slightly larger tire in profiles too tall to fit (think sport truck tires). Keep in mind that the 225-width tire will gain a few mm due to being stretched slightly from its meassured configuration (it'll look almost like a 235/50).
Norm
Gotcha! Sounds like I'm in agreement..
Now, 225/50 or 225/60? I personally like a meatier look to wheels, but don't want to sacrifice handling. And the 50's are 432$ a set, while 60's are 398$ a set (that makes alot of sense, more material!)
IIRC, a 195/70-14 is pretty close to OE tire dimensions. A 225/50-15 is about 7/8" shorter while a 225/60-15 is about 7/8" taller. If you're either raised or lowered at all that may make the difference a little clearer.
I don't think the 60's are going to give up much, given that you're out to 8" wide with them. Here's what 225/60-15 looks like in a hard turn on 15 x 8.5's on a slightly heavier car (3500-ish, and yes, I'm aware of the "extra" half inch).
Hope that helps.
Norm
Hope that helps.
Norm
I saw some 215/60/15's today at work, didn't look that bad, so the 225's should be good. Thanks for the info!
I completely redid the suspension, so it should be pretty tight underneath. 620's, 5leaf mideyes, KYB's, 1" & .75" bars, roller saddles, all new rubber & joints, braced, and new steering. Beefed up disc brakes allround too
