Engine coolant leak
Old Jan 11, 2009 | 12:46 PM
Randys289PONY's Avatar
Randys289PONY
Default Engine coolant leak
I have had an overheating problem on my 65 289 4v for some time.After replacing my leaky radiator,clearing any obstructions,cooler therm,I still had problems.I now have coolant that appears to be coming out at the timing cover just below the therm and it appears when just filling the engine with coolant.The intake man has been resealed and no coolant is coming out at hoses or gaskets above.Need Help! Here is a link to a photo
http://picasaweb.google.com/lh/photo...eat=directlink
Old Jan 11, 2009 | 12:48 PM
Starfury's Avatar
Starfury
Well, either it's leaking from the t-stat housing, or it's leaking from the timing cover. Check the underside of the t-stat housing to see if it's wet and dripping onto the timing cover. If you can determine that it's definitely coming from the timing cover, you'll need to pull all of your accessories off, pull the balancer, and remove the timing cover. If it turns out you need to do this, it's also a good time to replace the water pump, assuming you haven't done it recently.
Old Jan 11, 2009 | 01:01 PM
valley firearms's Avatar
valley firearms
It appears you are missing a bolt in the water pump. I believe that bolt is fairly long and bolts to the block. Replace the bolt and snug the rest of them and see if that is not the problem.
Old Jan 11, 2009 | 01:08 PM
Randys289PONY
Default RE.
I checked the intake seal and the therm seal underside both dry.I didnot know the timing cover had coolant inside.Just a Rookie Mech!!
Old Jan 11, 2009 | 01:12 PM
fakesnakes's Avatar
fakesnakes
It appears that you have one of the dreaded chome thermostat housings (looks chrome, but hard to tell in the picture). They are notorious leakers. Try as you may, they almost always leak eventually, particularly if they have the o-ring seal vs. gasket. If that is the leak and you are determined to keep it, clean everything carefully, glue a paper gasket to the block using gasket adhesive, then coat it with a gasket maker and carefully bolt the housing to torque. Let it sit for at least a day before refilling and starting the engine.
Old Jan 11, 2009 | 01:13 PM
fakesnakes's Avatar
fakesnakes
The timing cover does not have coolant inside. A couple of the bolts that go through the pump and cover and then into the block actually pass through the water jacket and must have thread sealer applied to the bolts.
Old Jan 11, 2009 | 01:54 PM
Starfury's Avatar
Starfury
Coolant runs through two passages in the outside of the timing cover to get to the water pump
Old Jan 11, 2009 | 01:55 PM
Randys289PONY
Thanks for the suggestions.This is my first mustang and I need all the help I can get. Is there any way I can find out size and length of the bolts that go into the water pump. I don't think the former installer used the correct parts.The pump is an Edelbrock and it was installed when former owner had the engine rebuilt in "94". Thanks again
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
mdj89
Sep 6, 2015 11:08 PM
zachary1988
Sep 4, 2015 03:04 PM
