40+ year old trunk gasket
Old Jan 12, 2009 | 12:23 PM
cpartridge's Avatar
cpartridge
Default 40+ year old trunk gasket
So I looked at my trunk gasket yesterday. I did not know rubber could transform into something both rock-hard and powdery at the same time : ) Anyway, is installing a new one as simple as glueing it on? Any tricks ?
Old Jan 12, 2009 | 12:30 PM
dcohen's Avatar
dcohen
get the old one off, glue the new one on
i dont think i would glue it all the way around, maybe a little bit of glue every couple inches
Old Jan 12, 2009 | 01:17 PM
kalli's Avatar
kalli
i used 3M weatherstripping adhesive. As far as i know that is exactly what was used to 'glue' it on. I think the original is yellow, but I used black. i used it the full way round. made a bead
http://www.shop3m.com/60455029946.html
Old Jan 12, 2009 | 02:25 PM
zmetalmilitia's Avatar
zmetalmilitia
I used the black 3M adhesive stuff too. Worked great, I put a bead around the trunk lid and the same on the weatherstrip, let them become tacky, then stuck them together. Super easy. The seam was at the hood latch/striker plate area on the trunk lid.
Old Jan 12, 2009 | 02:48 PM
kalli's Avatar
kalli
yep. exactly like that. worked very good
Old Jan 12, 2009 | 03:01 PM
chillininnh's Avatar
chillininnh
I installed mine while I had the car apart. It seems like it would be VERY difficult to do properly while the lid was installed.
Old Jan 12, 2009 | 03:07 PM
1slow67's Avatar
1slow67
ROTM Moderator
I have to replace mine. I think I have the original one on also.
Old Jan 12, 2009 | 04:59 PM
Carlos Pineiro's Avatar
Carlos Pineiro
Originally Posted by cpartridge
So I looked at my trunk gasket yesterday. I did not know rubber could transform into something both rock-hard and powdery at the same time...
Check under the trunk mat and the bottom of the quarters for rust. The worst and most likely place to get rust is the edge of your gas tank where water can collect in the groove.
Your replacement gasket is more poly than natural rubber and will last much longer and not harden liker the old one. Good luck.
CP
Old Jan 12, 2009 | 05:56 PM
kalli's Avatar
kalli
65 coupe is no problem with trunklid on car. fastback I have no idea
Old Jan 12, 2009 | 08:04 PM
rst08tierney's Avatar
rst08tierney
I made a thread about 9 months ago about the same. Very good answers helped me achieve good results. Make sure to read the section about the adhesive!!! Very important you use the 3 strand system explained.
https://mustangforums.com/forum/clas...-finished.html
