302 Torque Settings...
Old Jan 16, 2009 | 07:59 AM
mstg007's Avatar
mstg007
Default 302 Torque Settings...
Are all torque settings the same for most 302 engines? I have a old classic stang book that goes up to 64 1/2' - '73. The engine I am using now is a '89 302. Torque for the Heads and intake manifold.
Old Jan 16, 2009 | 10:17 AM
my77stang's Avatar
my77stang
they are the same
Old Jan 16, 2009 | 02:34 PM
flyingfool's Avatar
flyingfool
basicly same engine. so many if not all things do aply.
hey look! TWINS!
Old Jan 16, 2009 | 03:29 PM
fakesnakes's Avatar
fakesnakes
The only difference I have noticed is intake mainfold torque. The newer 5.0 is higher, but that may be due to the two piece EFI manifold. Everything else is the same from what I have seen.
Old Jan 16, 2009 | 04:40 PM
mstg007's Avatar
mstg007
Thanks guys. I will follow the specs!
Old Jan 16, 2009 | 07:57 PM
my77stang's Avatar
my77stang
fake, yeah you gotta watch that crap because they still use the same 5/16-18 bolts. my experience is that no matter what the application there is a torque rating of "xx" for a certain size bolt, which tells me its the strength of the threads that becomes the most important issue. IIRC 15-18 lbs. is a happy place for a coarse thread 5/16 bolt.
Old Jan 16, 2009 | 08:19 PM
fakesnakes's Avatar
fakesnakes
I absolutely agree with you on the bolts being torqued to the spec of the bolt and typically not the application, however I read dit differently in a couple of places and even a quick web surf show 23 - 25 ft/lbs here:
http://www.treasurecoastmustangs.com/bolttorque.htm
and here at RHS they show 35:
http://www.racingheadservice.com/Inf...Ford-Heads.asp
Personally, I've always used 25 and I agree with the chart in my first link.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
jaiidutch
Sep 14, 2015 10:29 AM
