T5 questions
Old Jan 16, 2009 | 01:11 PM
cfd2bc's Avatar
cfd2bc
Default T5 questions
Sorry didn't want to highjack the other post about the T5. I have started looking for one. I found a rebuilt one for 375. I assume that is a good price??
I have a 66 289. What years will work for me? How many spline shaft will work? What is the length that I need to get the driveshaft cut down to?
Thanks, Jeff
Old Jan 16, 2009 | 01:33 PM
Nick.Simonds's Avatar
Nick.Simonds
Read through some of these:
http://midnightdsigns.com/james/FAQs...0TRANSMISSION:
Old Jan 16, 2009 | 01:36 PM
kalli's Avatar
kalli
the price is very good in case it is a proper rebuild. but you need to make sure it's one for a V8 (so it holds up) as well as the year. only a certain range of years will do.
Old Jan 16, 2009 | 01:48 PM
cfd2bc's Avatar
cfd2bc
Do I need the "S-10" conversion to move the shifter forward? The web sites that Nick sent me to didn't mention that.
Good site though Nick..Lot's of info.
Old Jan 16, 2009 | 01:52 PM
gjz30075's Avatar
gjz30075
No, you don't need the S-10 conversion. A proper V8 T5 will line up the shifter in your car nearly perfectly.
Old Jan 16, 2009 | 02:23 PM
flyingfool's Avatar
flyingfool
if it wasnt from a V8, consider a new input shaft. thats the part that wont match up to the V8 (you can make it if you get a bearing from a mazda i believe.) the shaft in a T5 is two pieces. the input and the main. its a very simple task to pop them out.
Old Jan 16, 2009 | 08:21 PM
kalli's Avatar
kalli
when you fit a t5 the as mentioned above the shifter fits near perfect. i had to open the shifter hole by about an inch to the right and front. job done. since you have a 1966 i guess you have a 6 bolt bellhousing as you will need either a new bellhousing or an adaption kit to fit. but i guess all the links above will tell you all the options you have
Old Jan 19, 2009 | 11:46 AM
voipguy's Avatar
voipguy
I just did my swap in the last Six months.
Check this site out for some really good info.
http://www.moderndriveline.com/
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
