.....uhhhhh.... OPPS!
Old Jan 19, 2009 | 02:59 PM
Venomus68's Avatar
Venomus68
Default .....uhhhhh.... OPPS!
Well lets just start off by saying i'm here to learn from my mistakes and I hope in the future i wont screw up again...I was working on my engine earliar today and was trying to reinstall my power steering pump. All the bolts were just out of allignment, I and tried pushing the pump to where it needed to be. I thought it was all good so i put the bolt in. As i was tighting it to the head the bolt fell out with a pop and I realized the thread hole had fallin apart due to the tension and angle of the bolt. Does anybody have any ideas of how to fix this or any tricks to make it work back to normal condition? If so please let me know. The head is made out of Iron.
THANKS! -Mike
Old Jan 19, 2009 | 03:28 PM
Norm Peterson's Avatar
Norm Peterson
Got a picture?
If the hole isn't too badly damaged, and you're patient, reasonably skilled with a hand tap, and somewhat lucky you may be able to clean it up that way. Just don't count on whatever remains of the first few threads for anything and be careful torquing the bolt afterward so you don't strip what threads are left.
If it's worse than that, or you botch the above method by cross-threading the tap with the existing threads, you may be able to heli-coil repair it. Same deal with the above patience, etc., plus you absolutely must keep the drill bit aimed straight down the existing hole. Otherwise you'll end up with a perfectly threaded but cockeyed hole and the bolt will never ever screw in straight again. Never mind how I might know this.
Norm
urban_cowboy's Avatar
urban_cowboy
Iron heads are cast iron. There is not much that can be done to repair cast iron. Maybe a skilled welder could do something for you. I have seen cast iron breaks that my buddy has fixed, but it is not a great fix and he had a little bit bigger piece to work with.
Old Jan 19, 2009 | 03:36 PM
dodgestang's Avatar
dodgestang
Take your left head and put on the right side.
4reboy's Avatar
4reboy
JB weld? haha
Old Jan 19, 2009 | 04:07 PM
racin66coupe's Avatar
racin66coupe
dodgestang has a good point
Old Jan 19, 2009 | 05:02 PM
pnandy's Avatar
pnandy
new heads and more help from dad next time
Old Jan 19, 2009 | 05:09 PM
urban_cowboy
Man, dodge, you are a smart guy...good point. Swap the heads and don't screw up a again! Oh, and don't listen to 4reboy.
Old Jan 19, 2009 | 05:30 PM
Norm Peterson
Sorry, Mike. Work computer didn't even identify that there were picture links, never mind show the pics.
I agree, best to just swap the heads side to side on this one.
Norm
Old Jan 19, 2009 | 05:36 PM
1965fastback's Avatar
1965fastback
Ditto, that kinda stuff seems to happen at the worst times. At least you didn't crack the whole head.
