E brake problem
Old Jan 21, 2009 | 05:18 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default E brake problem
So I put my ebrake on last night and left it. Went out this morning to leave and disengaged it, well it didn't disengage. The handle and stuff moves, but the brakes won't disengage, what do I do? This is my DD so I need it fixed before tomorrow.
Old Jan 21, 2009 | 05:25 PM
1965fastback's Avatar
1965fastback
Check the cable and spray so Pb blaster or a similar product on the cable and let it set. Also make sure something isn't holding the tensioner in place.
Old Jan 21, 2009 | 05:28 PM
1slow67's Avatar
1slow67
ROTM Moderator
Either the tensioner is stuck or I broke something.
Old Jan 21, 2009 | 05:30 PM
1965fastback
I doubt it, jack up the rear end, pull off one of the drums and see if all the springs inside are still good. I would do this after you check the tensioner.
Old Jan 21, 2009 | 05:47 PM
1slow67's Avatar
1slow67
ROTM Moderator
Got it fixed. Looked inside where the cable runs from the handle outside the car and the cable was jammed between the wheel and the plate. My wheel was also pretty bent in several places so it couldn't spin. so I have no ebrake for right now. Will get pics tomorrow.
Old Jan 21, 2009 | 05:48 PM
1965fastback
Good to hear it was an easy fix.
Old Jan 21, 2009 | 05:50 PM
1slow67's Avatar
1slow67
ROTM Moderator
I was glad it was that quick, just used some needle nose pliers and pulled the pin out and popped off the wheel.
Old Jan 21, 2009 | 07:30 PM
baddog671's Avatar
baddog671
My GF hit a deer the other day and now her car is in the shop getting fixed. She needed a car to get to work while it is being fixed and the only car she could find was her grandfathers Saab. Nice car...
She forgot her cell at his house so she drives back, pulls in, and pulls the ebrake. Goes to leave, cant disengage it. Grandfather cant disengage it. Mom comes over, she cant disengage it.
Had to get it tow'd to the nearest Saab dealership (far away) for repairs, but they said its common for that year.
Moral: DONT USE THE EBRAKE DAMMIT!
Old Jan 21, 2009 | 07:32 PM
1965fastback
Well since his mustang is a manual, you kinda need the e-brake.
Old Jan 21, 2009 | 07:34 PM
baddog671's Avatar
baddog671
Nonsense:P leave it in gear
