heater vacuum motors
Old Jan 22, 2009 | 03:40 PM
jimmy428's Avatar
jimmy428
Default heater vacuum motors
can these little motors go bad (under dash on/around heater box) and more importantly can i get them anywhere new. thank you
Old Jan 22, 2009 | 03:53 PM
urban_cowboy's Avatar
urban_cowboy
Are you talking about the vacuum valve on the heater hose, the vacuum duct selector switch or what? Post a picture and location if you can.
Old Jan 22, 2009 | 09:30 PM
jimmy428's Avatar
jimmy428
i'll try and get a pic soon, but for now the best i can say is not the control on the driver's side and not the valve in the engine compartment. these motors/actuators are mounted on the heater box itself and have vacuum lines going in them. perfect example is the one you see under the dash on the passenger side. i feel that these may be faulty or even the switch under the dash that is mounted on the heater box itself. i believe it is some vacuum switch because it has a line goin in and out leading to the valve in the engine compartment. this leaks air/vacuum as i can hear it when the car is on so my heat problem is definitely vacuum influenced. pictures will be up soon.
Old Jan 22, 2009 | 11:05 PM
MIL1ION's Avatar
MIL1ION
Old Jan 22, 2009 | 11:29 PM
Starfury's Avatar
Starfury
Man am I glad I have a '67. Cable-linkages ftw...
Old Jan 23, 2009 | 10:19 PM
jimmy428's Avatar
jimmy428
i'm pretty sure the 67 heating is the same as the 68. correct me on that one, but anyway i found the new parts at mustangsunlimited.com
can i test these vacuum motors? can they go bad?
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
