Alum vs Steel wheel spacers... Thoughts?
Price isn't that bad you can buy them on ebay for $50-$60 a pair.http://cgi.ebay.com/ebaymotors/BILLE...Q5fAccessories
IMO alum wheel spacers are the way to go. How often do you take your wheels off? Also, if you are worried about wear then just make sure you don't over tighten anything. Its also MO that the weight you save using alum is almost negligible vs the steel spacers and as James stated, go with the cheapest. I have the alums on my 68 and I never worry about them. Best investment I've made so far.
I went with 1" aluminum billet spacers on my current truck project.
http://www.midnightdsigns.com/AJ/tru...ug08%20001.jpg
The difference between the 01-04 bullitts and the 05-09 bullitts is the offset.
If you're doing a restomod, going after a restomod look, or after serious performance where the necessary tires are not even available in the smaller diameters, sure.
For a car that's intended to look more or less "period-correct", no. Too much wheel that then needs a too-short sidewall just to physically fit in the wheelwell throws the classic proportions off.
I know a lot of the folks around the fringes of the "Pro-Touring" scene make sure that the tops of the tires are tucked up above the fender opening line, but I'd kind of call that a "Pro-Touring Lite" sort of thing (in many cases it's a look that's missing the real performance part of the equation).
Norm
Yeah,
I'm thinking 17s also, but must first sell my 16s.
http://albuquerque.craigslist.org/pts/989167439.html
