4 speed transmission
Old Jan 29, 2009 | 02:25 PM
luna 64's Avatar
luna 64
Default 4 speed transmission
Hello, I'm new to this forum. I need your help I am looking for parts or a complete transmission for my 64 1/2 mustang.I am told that it has a dagenham 4-speed. I will take pictures and post them later. The cluster gear and 1st gear are out on it as well as the 1st gear brass synchro. I appreciate any help that I can get.
Thank you,
Ray
Old Jan 29, 2009 | 03:31 PM
Starfury's Avatar
Starfury
I'd recommend swapping to a Toploader 4sp. The toploader is a far superior 4sp and is much easier to come by. David Kees @ http://www.4speedtoploaders.com/ is the guy to talk to.
You may also consider a T5 swap. T5's are plentiful in junkyard fox bodies. The only problem you might have is with your early style bellhousing. You might give Modern Driveline a call and see what they say about it.
Old Jan 29, 2009 | 04:29 PM
luna 64's Avatar
luna 64
Thanks for the info Starfury, Would you know of some other links where I may be able to repair this one?
Thanks,
Ray
Old Jan 29, 2009 | 09:17 PM
Starfury's Avatar
Starfury
Honestly, not a clue. I've never heard of one being repaired before, heh. You might call a local drivetrain/gear shop and see what they can do for you.
b8checker
Oct 8, 2015 12:55 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
