What Is It & What Does It Do?
Old Jan 30, 2009 | 09:57 AM
unit91's Avatar
unit91
Default What Is It & What Does It Do?
What's the round gizmo with the hole in the center just up and to the right of the throttle linkage? What does it do? It's not on the parts diagram from Ponycarbs and it's not in the Chilton diagram either.
Old Jan 30, 2009 | 10:12 AM
Norm Peterson's Avatar
Norm Peterson
Can't see it well enough to tell if it's got a wire connected to it or not. If it does, I'd suspect it's an anti-dieseling solenoid (lets the engine shut off instead of running on very roughly after you've removed the key from the ignition). If not, a dashpot to slow the rate of throttle closing (reduces HC spike). IIRC, both were early emissions-related pieces.
Norm
Old Jan 30, 2009 | 10:25 AM
urban_cowboy's Avatar
urban_cowboy
It looks to be a dashpot, like Norm said. Not sure what a HC spike is though. Need help with that one.
I thought it helped automatic cars from stalling from sudden throttle closures and the torque converter allowing the rpms to drop quickly.
Old Jan 30, 2009 | 10:34 AM
unit91's Avatar
unit91
Default better photo
This help? No wires attached.
Old Jan 30, 2009 | 10:46 AM
Norm Peterson
When the throttle is allowed to snap shut, there is a momentary increase in unburned HC emissions. If you were to plot HC emissions vs time, it would look like a spike sitting point-up. This is/was a major difficulty (read, expense) in getting manual transmission cars EPA-certified at the same power levels as their AT counterparts (and likely part of the reason that many cars have not offered the manual at all, expected sales not justifying the time and $).
Norm
Old Jan 30, 2009 | 10:56 AM
67fire's Avatar
67fire
The aluminum, shiny looking part that a 15/16" 12 point socket fits?
That would be a power valve on a Holley carburetor. It enriches the
carburetor during low vacuum situations.
Eric
Old Jan 30, 2009 | 11:44 AM
urban_cowboy
Norm, excellent information. As I said above, I thought the dashpots were for autos, but I cannot argue with your information. Good to know.
67fire, I thought about that, but the power valve in a Holley is on the metering block submerged in fuel and covered by the fuel bowl. This is on the outside of the carb.
Any idea what kind of carb this is?
Old Jan 30, 2009 | 11:45 AM
urban_cowboy
Stupid double post.
Old Jan 30, 2009 | 04:51 PM
unit91's Avatar
unit91
Supposed to be an Autolite 1100........
Old Jan 30, 2009 | 05:29 PM
65Coupester's Avatar
65Coupester
It sure looks like an 1100.
In the second photo, the thing that looks like a power valve is a valve used to regulate the vacuum to the distributor.
The automatic choke is on the left.
