Fuel pressure, 5psi?
Old Feb 5, 2009 | 01:14 AM
interwest's Avatar
interwest
Default Fuel pressure, 5psi?
Installed a Mr. Gasket electric fuel pump that was pushing 7+ psi to the carb so just put in a Holley pressure regulator and turned it down to around 5 psi. Any thoughts on the optimal psi?
Old Feb 5, 2009 | 02:08 AM
Starfury's Avatar
Starfury
I'd recommend 6-7psi.
Old Feb 5, 2009 | 03:31 AM
kalli's Avatar
kalli
just in case you wonder noone else is commenting. there are probably no other opinions ;-)
Old Feb 7, 2009 | 12:30 AM
interwest's Avatar
interwest
hahah cool thanks, I've been getting told around 5-7 from different shops around here.
Old Feb 7, 2009 | 09:11 AM
fakesnakes's Avatar
fakesnakes
What carb do you have?
If it is an Edelbrock, 5-6 is the most I would run. If it is a Holley or Holley clone, 6-7. If it or they are Webers, 3-4.
Old Feb 7, 2009 | 11:34 AM
hotrod351's Avatar
hotrod351
agree, id set it at 6-7 psi
Old Feb 7, 2009 | 11:39 PM
interwest's Avatar
interwest
Holley 650. I have it set right now at 5. Fluctuating from 7-10+ is no fun to drive around in. I guess I should have said, I'm trying to put a few miles on the motor before changing fluids and then finishing up some work like redoing the exhaust, rear axle, and msd box. Once all that's on I'm taking it down to get the carb dyno tuned.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
mrappe
Sep 26, 2015 10:16 AM
