Valve Cover Gaskets
Old Feb 6, 2009 | 12:15 AM
AndrewOlsen's Avatar
AndrewOlsen
Default Valve Cover Gaskets
I want to pull the valve covers on my 289 to inspect the valve train, and was just wondering what the proper method is for reinstalling them (what type of gasket, silcone, etc.)?
Old Feb 6, 2009 | 12:34 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you want to install them dry after cleaning and de-greasing the gasket surfaces. get some rubber reusable ones with metal inserts to prevent over tightening, this will prevent leaks
Old Feb 6, 2009 | 02:41 AM
Starfury's Avatar
Starfury
I have rubber gaskets on my engine and I love them.
Old Feb 6, 2009 | 07:49 AM
my77stang's Avatar
my77stang
yeah they are the shizz. if you end up using cork, use weatherstripping adhesive on one side and make sure they are nice and stuck to the surface before you apply permatex to the other side and tighten them up, or there is a good chance they will slip around and cause leaks.
Old Feb 6, 2009 | 07:53 AM
chappys4life's Avatar
chappys4life
With the rubber ones do you have to use silicon?
Old Feb 6, 2009 | 08:10 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
no you install the rubber ones dry, i actually install all valve cover gaskets dry on my 302s etc
Old Feb 6, 2009 | 03:12 PM
jlg2002's Avatar
jlg2002
Just a trick from the old-school:
Use a little bit of common axle grease on your gasket faces (especially cork) and they'll slide more without becoming disloged. I did it for years (still do) when I was still turning wrenches for a living. These new rubberized gaskets with the metal bolt rings are the best, especially if you want to get under the covers more often. I still like cork for long term installations. done right they'll last for along time.
Jlg
Old Feb 6, 2009 | 03:34 PM
SJs 66coupe's Avatar
SJs 66coupe
http://www.parts123.com/parts123/yb....P17.95~~~~~~~F
Looks like the gaskets are cheap enough.
I have been kicking around taking my valve covers off to paint them and generally clean them up.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dathan
Oct 5, 2015 05:52 AM
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
