Idler Arm Help
Old Feb 6, 2009 | 03:13 PM
jonward786's Avatar
jonward786
Default Idler Arm Help
I can't seem to get this idler arm out. Here is a pic of the side that wont come off. The nut just wont budge....
http://i435.photobucket.com/albums/q...d/IMG_0352.jpg
Old Feb 6, 2009 | 07:35 PM
69mach1377's Avatar
69mach1377
Have you soaked with liquid wrench and tapped it?
Old Feb 6, 2009 | 09:14 PM
racin66coupe's Avatar
racin66coupe
PB blaster, breaker bar with a cheater pipe. or a very strong impact gun
Old Feb 7, 2009 | 11:38 AM
hotrod351's Avatar
hotrod351
you can try using a dremel with a cut off wheel to cut the nut. or another idea is use a propane torch to heat it up, then it should come off easy. id try the propane torch first.
Old Feb 8, 2009 | 10:23 AM
jlg2002's Avatar
jlg2002
Yeah, anything that increases your leverage, like a pipe, or a very strong impact gun. Like previously stated, you can apply heat or they have nut crackers, which minimize damage like a dremel might cause if it gets away from you. (I had to use one on my 66 to cut the nut off of my pitman arm)
guitarman376
Oct 11, 2015 01:47 AM
UrS4
Oct 3, 2015 06:23 AM
UrS4
Sep 30, 2015 10:13 AM
03blackwidow
Sep 20, 2015 02:36 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
