ARGH!@#%$ Fastback = Broken (rant)
Old Feb 11, 2009 | 01:41 PM
Starfury's Avatar
Starfury
Hahaha:P
Ok, update: turns out I don't have an ignition problem. In my haste button things back up on the side of the road, I forgot that I disconnected my distributor ground to get the valve cover off. Distributor is grounded to a screw on the alarm, which is on the d-side inner fender. No ground = no distributor electronics = no spark. Reconnected ground, fires right up....and knocks. Now it's a more regular knock, once every other crank revolution. Sounds like piston/valve interference=/ Going to pull a valve cover and crank the engine by hand.
Worst case, I misadjusted one of the rockers, bent a valve, and maybe flattened a lifter. Stupid. But if that's the case...I suppose it gives me a reason to put decent heads on it. I might end up selling the '90 GT to pay for them though I dunno, we'll see. I'm at the shop right now, gonna get back to work
Old Feb 11, 2009 | 05:04 PM
Starfury's Avatar
Starfury
Ok, problem solved, car runs fine now. After much hair pulling, readjusting the d-side rockers one by one, compression checking, and more hair pulling, one of my shop teachers had a listen to the then present 'knock' and determined that it wasn't a knock, it was a mean pop out the intake due to an exhaust valve not opening. Turned out to be a p-side rocker that I apparently didn't tighten the set screw on that worked its way loose. Fixed it, car runs perfectly.
UGH.
Old Feb 11, 2009 | 09:03 PM
cprstreetmachines's Avatar
cprstreetmachines
After you tighten the set screws, give it another small 1/16 turn or so. Snug it up and that will really lock it down. Set screws by themselves are tough to get to lock, especially if not of the top of a flat stud by ARP. Ones with the dimples in the center of the stud are a real PITA
Old Feb 11, 2009 | 09:46 PM
1965fastback's Avatar
1965fastback
At least it wasn't a big deal!
Old Feb 11, 2009 | 11:10 PM
racin66coupe's Avatar
racin66coupe
wooOO!!
Old Feb 11, 2009 | 11:52 PM
valley firearms's Avatar
valley firearms
Damn, I thought you were going to say the knocking sound was Glenn wanting back in
Old Feb 11, 2009 | 11:53 PM
Starfury's Avatar
Starfury
They're actually Comp Cams studs with flat tops. I don't think it worked itself loose on its own, I think I just didn't snug the screw down enough. I torqued the rest of the down pretty good, I think I just missed the one. I feel stupid, but no actual damage was done. Car runs great now.
Old Feb 12, 2009 | 05:29 AM
fakesnakes's Avatar
fakesnakes
Hey, as they say **** happens! No foul and you are good to go. Glad you got it worked out.
Old Feb 12, 2009 | 05:58 AM
jonward786's Avatar
jonward786
Originally Posted by Starfury
Car runs great now.
Not as well as mine
Old Feb 12, 2009 | 06:24 AM
vescotech's Avatar
vescotech
Glad you got your problem solved. The education that problem gave you thuogh is priceless. Sound like your shop teacher has heard a few exhaust cam lobes worn out in the past.
