Reproduction Stereo
Old Feb 17, 2009 | 01:21 PM
MIL1ION's Avatar
MIL1ION
Mustang radio bezels do not have a straight across mount,. they have an Offset mount and any aftermarket radio to be mounted in these bezels will have to have the special offset shafts.
I would go with one of those new special Mustang decks.
Old Feb 17, 2009 | 04:12 PM
fakesnakes's Avatar
fakesnakes
I found this one, but know nothing about it:
http://www.crutchfield.com/p_068RETR...&tp=5684&avf=N
I does accomodate the offset left ****.
Old Feb 17, 2009 | 04:26 PM
Starfury's Avatar
Starfury
Alternator upgrade will depend on the sound system you decide to run. If you have a separate amp, then yes, I'd probably recommend switching to a higher output GM or Ford style alternator.
Old Feb 17, 2009 | 04:59 PM
MIL1ION's Avatar
MIL1ION
I wonder about the opening for the radio face ?
Old Feb 17, 2009 | 05:02 PM
palerider's Avatar
palerider
I've got the custom autsound also. Only have had a short period of time but bought anyway even after hearing negative posts. Just wanted to have something more original looking. Hooked up to center speaker I got from NPD it's a 6x9 with 2 tweeters and a left and right channel. I'm running a stock alternator. Would not worry about upgrading unless you plan on putting in an amp or powered subwoofer.
Started with the thought that I would just put center speaker and be done with it. But ended up putting 6x9s in back to give more overall sound. Just recently added 4 1/2s into special kick panels. But I'm the type that can't leave well enough alone. Have not had unit long enough to discuss longevity - I'm fine with sound but I'm not a big stereo guy.
Old Feb 17, 2009 | 05:49 PM
sdn's Avatar
sdn
Thanks again, great info.
Still nobody out there using the Custom Autosounds Undercover speakers? Do they even fit under the seats?
Old Feb 17, 2009 | 05:53 PM
nba1341's Avatar
nba1341
I use a custom autosound USA-630, used to use a USA-6 until i fried it
anyways if you want good sound i suggest putting an 4 channel amp and powering the speakers through that. Very easy to wire under the carpet.
Old Feb 17, 2009 | 05:55 PM
nba1341's Avatar
nba1341
btw my 60amp alternator held up fine for 2 years on my 160watt rms amp and radio that is with my electric fan on all the time
now that i have upgraded my speakers and amp it cuts out
so it all depends on how powerful the system was
jrrhd73must
Oct 2, 2015 09:17 PM
vbonina
Sep 22, 2015 08:31 AM
Ford_Dude
Sep 15, 2015 03:25 PM
TimeLord101
Sep 4, 2015 09:27 AM
movielover40
Aug 27, 2015 10:13 PM
