Differnce with speedo between...
Old Feb 18, 2009 | 01:59 PM
Starfury's Avatar
Starfury
Ya know, I calculated for % difference in tire height (which I did correctly, thanks Million:P), but not circumfrence. Teach me to try to do math right after I wake up...
Rangoon got it, though
Old Feb 18, 2009 | 02:50 PM
MIL1ION's Avatar
MIL1ION
Originally Posted by kalli
you have the value twice on a tyre (38mm ~ 1.5")
the diameter is this value above the rim and below the rim + the rim size
so the values that are standing now in 65rangoons post are as exact as you could get them. it will still slightly differ from what the manufacturer will tell you about the circumference and revs/mile
I know, I only commented on Tire height from road to rim.
I never got into circumference because I didn't need to arriving at the..road to top of tire height.. is up to the other guy. You assumed I was supposed to provide that,when the guy just before as it turned out ..posted it.
The specs stamped on the tire are what I based my info ,that I provided.
Maybe manufacturers should start stamping circumference so people don't have to do the math and double the sidewall measurement ?
67LimeCoupe
Nov 25, 2015 08:55 PM
Mr. D
Tuner Central
Aug 27, 2015 05:01 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Gregz
Aug 11, 2015 03:42 AM
Monty
Mar 3, 2004 09:48 PM
