Antenna Delete Kit
Old Feb 23, 2009 | 09:36 PM
Stangman70's Avatar
Stangman70
Default Antenna Delete Kit
Anyone know where to get one? Are they the same thing as the hidden antenna kit from mustangs unlimited? My antenna is the 68 round base. Earlier this year my gf's cat, in an act of guerrilla warfare, broke the antenna while under a car cover. Naturally I was devastated. So I am resorted to techniques that will allow me to keep the car undamaged, while it is in storage.
Old Feb 23, 2009 | 09:41 PM
1slow67's Avatar
1slow67
ROTM Moderator
Depending on how much you want to spend you could always use the power antenna kit.
http://www.mustangsunlimited.com/ite...atkey=EMUSTANG
Old Feb 23, 2009 | 09:42 PM
LCC's Avatar
LCC
Bye bye Kitty..
Old Feb 23, 2009 | 10:00 PM
uibalnme's Avatar
uibalnme
Originally Posted by LCC
Bye bye Kitty..
+1
ROFL
Old Feb 23, 2009 | 10:21 PM
Stangman70's Avatar
Stangman70
Yeah, I wish it was that easy. I've been at war with this animal for the last year. There are so many claw scratches on my car its not even funny. Any idea how to get them out?
Old Feb 23, 2009 | 10:25 PM
1slow67's Avatar
1slow67
ROTM Moderator
Depends on how deep they are. Meguiars ScratchX supposedly works with fine scratches.
Old Feb 23, 2009 | 11:09 PM
Nabster's Avatar
Nabster
I'm glad my antenna has two small set screws at the base. Loosen them and it pulls of leaving just a little ****. No problems with a car cover.
Old Feb 24, 2009 | 04:08 AM
MonsterBilly's Avatar
MonsterBilly
a lottle turtle wax and a soft cat hair cloth should do the trick. dont bother skinning the cat. just use some elbow grease
Old Feb 24, 2009 | 08:36 AM
mortman's Avatar
mortman
If your going to paint, i would (and did) weld a plate under the antenna hole and us filler to fill it in. Use an amplified antenna from there. The amplified antennas work great until you drive next to high powered tension lines you'll loose reception till you pass them.
Old Feb 24, 2009 | 08:49 AM
andrewmp6's Avatar
andrewmp6
Could try this http://www.ecshylites.citymax.com/page/page/761353.htm if you do remove your antenna don't use filler to fill the hole.Weld it up or fiberglass it.And tell your gf the cat ran away.
