painting interior panels
This worked great for my doors. I scuffed with Scotch Brite and then sprayed. The scuffing did not damage the texture. The nozzle on this paint is better than most. It gives a nice vertical pattern. It runs very easily though. It also was a dead on perfect match to original.
If your talking about the interior panels on a fb some are plastic and some are metal. I don't think there is a need to scuff or strip. Just clean them up before you paint. I used the satin/semi gloss black rattle cans from dupli-color available at any auto parts store. This is close to the factory dull finish for the interior panels. There is an adhesive promoter available by dupli-color that I used too beforehand. A couple of coats and you should be good. There isn't much you can do to prevent scratching, but it is simple to repaint.
Try a panel by this method and it will look correct, if not, you're not out much, only $10.
steel wool baby, then wipe it down with lacquer. Make sure you primer the metal to prevent this from happening again.
