Anything wrong with moving the engine back a tad?
Old Mar 10, 2009 | 10:59 AM
Nick.Simonds's Avatar
Nick.Simonds
Default Anything wrong with moving the engine back a tad?
I will be using Ron Morris engine mounts for my build along with T5. Any reason I can't move the engine back .5-.75" to align with the hole? I know I will still have cut the other direction though. Since I have no drive shaft already I figured it shouldn't be a problem.
Old Mar 10, 2009 | 11:20 AM
JamesW's Avatar
JamesW
just watch your other clearances such as valve cover to M/C, hose lengths, headers to shock towers, etc.
Old Mar 10, 2009 | 11:26 AM
Nick.Simonds
Ewww yeah. That shock tower clearance would probably be a problem with the 351w in there.
Old Mar 10, 2009 | 11:32 AM
Nick.Simonds
I guess I will have to mock everything up and play with clearances. Yuck
Old Mar 10, 2009 | 11:34 AM
JamesW's Avatar
JamesW
I used regular 66 motor mounts and had to trim the tunnel a little bit. I used a jig saw with a metal cutting blade to open it up a bit. The shifter boot and console still fit fine.
http://www.midnightdsigns.com/james/...sole%20003.jpg
You can buy a really nice jigsaw for the $225 it cost for the floating motor mounts. *S*
Old Mar 10, 2009 | 11:38 AM
Nick.Simonds
What part of the tunnel did you trim? The shifter opening?
Old Mar 10, 2009 | 12:27 PM
JamesW's Avatar
JamesW
Yes,
I'm running a B&M shifter on my T5 and it had a week bit if interference with the tunnel in the front of the opening. I just rounded it out enough to clear.
Old Mar 10, 2009 | 06:59 PM
Scott H.'s Avatar
Scott H.
Old Mar 10, 2009 | 07:14 PM
Joe67's Avatar
Joe67
Banned
if you want to cut back from $225 for a jigsaw,
try one of these bad boys.....
http://www2.northerntool.com/air-too...item-15764.htm
rather expensive there, but i guess quality is better than here?
http://www.harborfreight.com/cpi/cta...Itemnumber=113
Old Mar 10, 2009 | 08:14 PM
Nick.Simonds
I have all the stuff to cut the metal, I just don't want to. I am going to just go ahead and splurge on the RM mounts, they look very solid.
