2001 Mustang 4.6 Motor in my 67 questions
Old Mar 10, 2009 | 05:39 PM
pimp2303's Avatar
pimp2303
Default 2001 Mustang 4.6 Motor in my 67 questions
how much fab work would need to be done... i know a lot of electrical stuff but i meaaan fabrication. i have the motor and tranny and rear end for one. would i have 2 get custon motor and tranny mounts made or do they sell them on the market somewhere. has anyone done it... if so any pictures of progress and/or finished work.
Old Mar 10, 2009 | 06:03 PM
stangtjk's Avatar
stangtjk
Here are links to the motor mounts and trans mounts from DVS restorations.
http://www.dvsrestorations.com/transmissionpage.html
http://www.dvsrestorations.com/motormounts.html
The 4.6 is a lot wider than a 302 so you will have to notch the shock towers. Most people just go with a MII front suspension to eliminate the shock towers. You may have to modify the trans tunnel as well.
I'm building a restomod with a 4.6 DOHC with the suspension from a Mark VIII. I fabricated the complete floor from front to back and the whole front end but you wont have to do all that. Check out modularfords.com they have a modular conversion forum. Should be able to get a lot of info and help over there.
Here's a few pics of my work in progress.
Old Mar 10, 2009 | 08:32 PM
Nick.Simonds's Avatar
Nick.Simonds
Why would you need to switch the rear end?
Old Mar 10, 2009 | 10:51 PM
my77stang's Avatar
my77stang
if your planning on using a 2 valve 4.6 don't waste your time, they are friggen pigs. now if your talking the 4 valve cobra/mark viii motor or a 3v motor from a 05+ thats another story.
Old Mar 11, 2009 | 07:48 AM
andrewmp6's Avatar
andrewmp6
You will have to notch or remove the shock towers maybe trim the tranny tunnel depending which tranny your going to use.The rear end i wouldn't use a 9 inch is stronger and you can buy ones that will bolt right in.I don't get why all the work and its only a 281 i rather build up a big block or stroker small block.
Old Mar 11, 2009 | 09:55 AM
stangtjk's Avatar
stangtjk
Well he said hes already got one laying around so maybe he doesn't want to spend money building a whole new motor.
Old Mar 11, 2009 | 10:01 AM
Nick.Simonds
It would probably be cheaper rebuilding an old motor than modifying it to fit a 4.6 and transmission.,
Old Mar 11, 2009 | 10:13 AM
stangtjk's Avatar
stangtjk
Well I guess that all depends on who you ask. I got the same type of comments when I started building my mustang. I put in the 4.6 DOHC, 4R70W trans, four wheel disc brakes w/ hydroboost, power rack and pinion steering, new rear quarters, stripped the car and put it in epoxy primer.... I still havent spent $1000.
Old Mar 11, 2009 | 11:40 AM
Nick.Simonds
And I guess It also depends on who's giving you all the free stuff.
Old Mar 11, 2009 | 01:40 PM
stangtjk's Avatar
stangtjk
Nick.Simonds And I guess It also depends on who's giving you all the free stuff.
Nope. Even if I had to pay for the stuff I got for free I would still have less than $1000 in my conversion. I gave $600 for the Mark VIII and sold the body for scrap after it was stripped for $200. I used two 24' lengths of tubing and roughly 2 4'x8' sheets of 16ga so around $200 for the metal (which is the only thing I got for free). That puts me back up to $600. Quarters were $200 shipped, primer was $89 and the hydroboost was $53. I also bought 2 steering ujoints for $25 and my fuel line was $30. That puts me at around $967. The quarters and primer I wouldn't count as far as the conversion goes so that would only put me at $678. I've still got the engine, trans, rear end, and front suspension parts from the mustang that I need to sell so by the time its all said and done I'll have very little money tied up in the car just a lot of time. I'm not saying that I have every thing I need already, there are still a few more things I need to buy but it is still going to be a pretty inexpensive build.
