Voltmeter jumping problem
Old Mar 14, 2009 | 07:55 PM
stooges's Avatar
stooges
Default Voltmeter jumping problem
I installed an aftermarket voltmeter this weekend on my '73 Mach 1, 351C and upon starting the car, the needle is jumping all over the place. In accessory position (car not running), it shows a constant 12V, and at higher rpms, it smooths out at 13/14V. Any help on this one?
Old Mar 14, 2009 | 09:08 PM
JamesW's Avatar
JamesW
Are you confident you've got a solid ground connection?
Old Mar 14, 2009 | 09:42 PM
LCC's Avatar
LCC
Sounds like the voltage regulator for the alternator may be going bad. I would start by using a multimeter at the bat and see if it's bouncing there and if not check your connections to your volt meter in the car, you may have it wired wrong.
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Beerman309
Sep 19, 2015 01:16 AM
TfcCDR
Sep 14, 2015 12:08 PM
