help???
Old Mar 21, 2009 | 08:44 AM
matt7771505's Avatar
matt7771505
Post help???
hi im matt and im new.
i have a 71 coupe 302 2b
i have a few ??? about the timeing.
1- if the timeing is off will it mess up the eng.
2- how would i know if the timeing is off?
3- how do i fix my timing.
i have a more ??? if there is some one out there willing to help.
Thanks, Matt
Old Mar 21, 2009 | 10:20 AM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
Welcome to the forums. You will get a better shot at having your ?'s answered by posting in the correct section. Here is your section: https://mustangforums.com/forum/classic-mustangs-16/
Old Mar 21, 2009 | 10:25 AM
Timspony's Avatar
Timspony
SVT Section Moderator
Welcome Matt!! ...need a timing light for starters!! ...too much engine timing can hurt the 302!
Old Mar 21, 2009 | 10:55 AM
PennState's Avatar
PennState
welcome, deff try the tech secs.
Old Mar 21, 2009 | 10:59 AM
zkeele's Avatar
zkeele
Definitely can hurt the engine, if it is off quite a bit. But just a little shouldn't hurt anything. It obviously would be best to set it properly. Good luck.
Old Mar 21, 2009 | 12:00 PM
Starfury's Avatar
Starfury
Advance at idle with the vacuum advance hose disconnected and plugged should be 8-10*. Total advance (w/hose still disconnected) should hit 30-36* by 3000rpm.
Old Mar 21, 2009 | 12:40 PM
matt7771505
thanks guys
the thang is i dont know that much about it.
the eng. runs and its drivable, but when i hit the gas its almost like the air/fuel ratio is off. tought it might be the timing.
please reply.
Old Mar 21, 2009 | 01:39 PM
Starfury's Avatar
Starfury
Very well could be, but you need to get yourself a timing light and check it.
I'd strongly recommend you fork the $40 for a factory service manual. It will tell you how to do pretty much anything to your car that you'll ever need to do, shy of body work, including checking the timing.
Old Mar 21, 2009 | 04:56 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
+1 on the timing light and the service manual best money you can spend for wrenching on your car
