using manual steering adapter
Old Mar 21, 2009 | 12:42 PM
redstallion's Avatar
redstallion
Default using manual steering adapter
I've got a 67 that originally had power steering....after years of repairing it I decided to just cut the PS belt and do without.
I've seen the manual steering adapters that replace the control valve for about $120, but my question is...Is this my best option??? As far as handling/being tight goes, is it just as good as replacing the linkage with the original manual style?
Thoughts? Thanks.
Old Mar 21, 2009 | 01:38 PM
Starfury's Avatar
Starfury
Well, ideally you want as few joints as possible, which would mean switching entirely to manual linkage. That can get pricey, however, hence the steering adaptor.
Old Mar 21, 2009 | 01:54 PM
BigIron22's Avatar
BigIron22
I have the manual steering adapter. i have a new steering box new inner and outer tie-rod ends, new idler arm, and a new rag joint. the only things i have not replaced are the steering column and the center link. Also have all new front suspension. and I still have a bit of play in my steering system. I have been thinking about welding up the manual steering adapter to make sure there is no side to side movement in the adapter.
Old Mar 21, 2009 | 03:37 PM
gjz30075's Avatar
gjz30075
That's odd, I would have thought those things are solid already.
Old Mar 21, 2009 | 07:01 PM
BigIron22's Avatar
BigIron22
the stud that connects to the pitman arm has a round base like the one in the power valve. you can't move it with your hands. but i think the force from the steering box and fricition from road may make it move. That is why i'm thinking about welding it solid to eliminate any chance of movement.
Old Mar 22, 2009 | 12:19 AM
stanger53's Avatar
stanger53
Weld it solid to what?
Basically, the adapter takes the place of what would be a swivel ball stud on the end of a manual steering centerlink. It is a moveable ball stud for a reason. Even though there is play and swivel movement in all the components that bolt to the centerlink, there needs to be a slightly moveable stud connecting to the pitman arm to keep there from being any binding as the linkage moves back and forth and the suspension moves up and down. Making it a solid unit is not a good idea.
The manual steering adapter is just a copy of what Ford used on the early 1960's big Fords with manual steering. It is just designed down to fit the smaller linkage of a Mustang.
The ball stud in the adapter is mounted under spring pressure, tight enough to keep the play down to a minimum, but still allow the ball stud to swivel without binding. Because of this, there will always be a tiny bit more play in the adapter than if you converted to a manual steering centerlink.
http://www.stangerssite.com/manualadapter6770.html
Old Mar 22, 2009 | 01:40 AM
vineman's Avatar
vineman
so is this something that gives you the ability to use a power steering gearbox for manual steering?
Old Mar 22, 2009 | 02:15 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the 65-70 cars use an add on p/s system with an external cylinder ram.
1971-1973 cars use a GM saginaw steering box that is an internal setup. to convert Your car to manual steering you have to have one of the rare 71-73 manual boxes to swap into your car.
Old Mar 22, 2009 | 02:19 AM
vineman's Avatar
vineman
ah...damn. oh well
Old Mar 22, 2009 | 02:31 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ah...damn. oh well
if you want to convert to manual steering look for base model sixxers a lot of them had manual steering.
ive had 7 71-73 cars and only one has been M/S i like it so much more.
idk what the part number is for the box but you might be able to get one through flaming river etc
CS2007
Jun 25, 2019 09:45 PM
Ken_in_d
Apr 15, 2016 02:25 PM
ChampInSD
Oct 2, 2015 04:55 AM
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
