Upper control arm drop
Old Mar 23, 2009 | 02:59 PM
JERM_1967stang's Avatar
JERM_1967stang
Default Upper control arm drop
this is the shelby drop right?? and does this look like a good price or should i make my own from my house? http://www.mustangdepot.com/OnLineCa...wering-jig.htm and which one should i get the 3.75 spacing or 4.75 spacing? thanks and does this really help like people make it out to be? and also what exactly does it do. does the ride height change? i would assume it would lower it. thanks
Old Mar 23, 2009 | 03:11 PM
Nick.Simonds's Avatar
Nick.Simonds
Woah....that is ridiculously expensive.
If you want to buy one, buy from Day $25.99 SHIPPED. That comes with the drill bit.
http://home.bresnan.net/~dazed/test
Old Mar 23, 2009 | 04:11 PM
Adrenolin's Avatar
Adrenolin
Yeah thats a bit ridiculous isn't it! Just order it from Dazed.. save money and support a guy whose helped out a lot.
Old Mar 23, 2009 | 05:57 PM
fakesnakes's Avatar
fakesnakes
Not only is that a crap price, it is a crap template! You can't just start drilling with a 17/32" or 1/2" drill bit. You need to start small. Dazed's set up comes with the original upper arm holes already drilled and full size. You bolt it right in place on your car. The new lower holes, however, are only 1/8". This way you can drill a precise 1/8" starting hole in the car. You not be able to do this with that template with the giant hole. Just try to manually find the center for your first holes!
BTW, the smaller size is for 65/66 and the larger for 67-70.
Old Mar 23, 2009 | 06:24 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
+1
The pilot holes in Dazed's template made the drop a walk in the park.
Old Mar 23, 2009 | 06:59 PM
JamesW's Avatar
JamesW
why not just use the paper template and make one?
http://site.cobranda.com/tech/aarms.pdf
Old Mar 23, 2009 | 09:00 PM
flickjo68's Avatar
flickjo68
Not trying to steal the thread but does anybody have any before and after pics of the ride height change? Also, how does it affect the alignment specs?
Old Mar 23, 2009 | 09:04 PM
1slow67's Avatar
1slow67
ROTM Moderator
I might have a few pics
Old Mar 23, 2009 | 09:13 PM
flickjo68's Avatar
flickjo68
I'd appreciate it BA,
Off topic, but are you going to bring back the thread about the 45th anniversary?
Old Mar 23, 2009 | 09:16 PM
1slow67's Avatar
1slow67
ROTM Moderator
I will
