Problem w/ '70 mach 1
Old Mar 26, 2009 | 02:42 AM
Awol5010's Avatar
Awol5010
Default Problem w/ '70 mach 1
Hi guys,
Brand new to the forum.
I drive a 1970 Mach 1 351 4-speed, which has been running fine lately. However, today I couldn't start it for the life of me. The battery is charged, gas tank is full, but the engine just won't turn over. I've tried everything I can think of but still can't get it started up.
Any thoughts/ideas?
Thanks!
Old Mar 26, 2009 | 10:29 AM
palerider's Avatar
palerider
Not cranking at all could be a number of things. Battery, loose ground cable, neutral safety switch - Do your lights or blinkers work?
Old Mar 26, 2009 | 10:33 AM
cdeck714's Avatar
cdeck714
if the engine is spinning and won't start then start with the basics. Is it sparking? Is there gas getting to the carb? Is the air cleaner clogged? spark, gas, and air is how I start diagnosing the problem.
Old Mar 26, 2009 | 01:29 PM
69mach1377's Avatar
69mach1377
Sounds like the starter is not working, at all...
Old Mar 26, 2009 | 01:34 PM
69mach1377's Avatar
69mach1377
Old Mar 26, 2009 | 01:41 PM
dodgestang's Avatar
dodgestang
Clean your battery cable connections.
Old Mar 26, 2009 | 04:54 PM
lunarweasel's Avatar
lunarweasel
.... and then post some pictures!
Old Mar 26, 2009 | 05:24 PM
4reboy's Avatar
4reboy
is it in park?
Old Mar 26, 2009 | 09:15 PM
Awol5010's Avatar
Awol5010
Thanks everyone, I'll be sure to check everything out! Take care
Old Mar 26, 2009 | 09:49 PM
Cruzzar's Avatar
Cruzzar
Could be a bad starter selonoid, you could bypass it with a remote starter switch and see if it will then turn over. It could also be a bad starter switch. Are you close to Visalia, Ca.?
