How Long Can a Tranny Sit on a Bench and Still Be OK?
Old Apr 6, 2009 | 05:14 PM
pekoe1111's Avatar
pekoe1111
Default How Long Can a Tranny Sit on a Bench and Still Be OK?
I am looking at a '66 in which the seller switched the transmission from an automatic to a standard. He put the automatic on a dry workbench where it has sat for 20 years. What should be done to make sure it will be OK to put back in? How can I or a mechanic tell if it is OK?
Thanks
Old Apr 6, 2009 | 06:13 PM
vineman's Avatar
vineman
You could look in side in the valve body and at the gears to see for rust or corrosion and turn the shaft to see if it'll turn and engage the gears without binding. If it had trans fluid left in it then it may be ok but I wouldn't recommend just running as is though. I had an engine that sat for 5 years with oil in it up to the heads and once it was emptied and refilled it turned right over.
Old Apr 6, 2009 | 06:16 PM
jc92073's Avatar
jc92073
The seals might be dried out. I would just get a rebuild kit and replace the seals and clutches. If it is a C4 or C6 they are simple to take a part. Kit with clutches and seals is $50-$100.
Old Apr 6, 2009 | 07:21 PM
pekoe1111's Avatar
pekoe1111
Default How Hard to Rebuild It?
I have basic mechanical skills. How hard is it to rebuild it? It is a stock '66 automatic so I don't know if it is C$ or C6. Any tricky procedures or special tools? How hard is it to pull the standard transmission and put this back in?
Old Apr 6, 2009 | 10:19 PM
jc92073's Avatar
jc92073
they are easy to rebuild. Not many special tools, just snap ring pliers. I clutch spring compressor will make it easier, but you can use a couple of C clamps.
Swapping the transmissions won't be hard. You will need the floor shifter and linkage and transmission cooler lines. If he kept all that, it will be simple.
Old Apr 6, 2009 | 11:45 PM
vineman's Avatar
vineman
Yeah like JC said. Going from manual to auto is way easier and less time consuming but you will need all those parts. I've never rebuilt a trans but would probably have it professionally done the first time if it were to be put in a car that was to be used a lot as opposed to here and there.
GPR
Dec 16, 2015 12:21 PM
Gene K
Oct 21, 2015 11:37 PM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
