Power Steering Fluid
Old Apr 17, 2009 | 09:37 AM
nassaubayman's Avatar
nassaubayman
Default Power Steering Fluid
Back in the day it was common practice to put ATF in the power steering system. Does anyone still do that?
I'm going to replace my C4 transmission with an AOD out of a '92 Mustang LX. I've been told to use Dextron/Mercon III instead of Type F fluid.
I haven't gotten into the power steering system on this car yet, but it has a leak. I haven't pinpointed where the leak is coming from, but something is going to replaced soon - either hoses or the pump itself. Fresh fluid will be going in.
Is it time to buy some overpriced "power steering fluid"? Stick with Type F? Or switch to Merc III since I'll be using that for my AOD?
Old Apr 17, 2009 | 12:39 PM
jcthorne's Avatar
jcthorne
Stick with the type F in your steering. If at some point you do a full rebuild of the power steering system with new hoses, cylinder and pump, then you can go to the newer mercon fluid. My rebuild C4 now runs Mercon. Not a good practice to mix the fluids though.
Old Apr 17, 2009 | 01:11 PM
jonward786's Avatar
jonward786
why on earth do i keep hearing people say PS fluid is overpriced? its cheap as hell...
Old Apr 17, 2009 | 01:53 PM
Tomrob77's Avatar
Tomrob77
The type F fluid is going out of production and being replaced by type FA. At least thats what the guys at the classic automotive supply store told me so idk if thats true.
Old Apr 17, 2009 | 06:31 PM
stanger53's Avatar
stanger53
Use the Type F fluid as the factory recommends. It is what the seals and hydraulic system was designed to use. Also, Type F doesn't thin out as easily as other fluids, which can cause a pressure loss in the system.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
stark777
Sep 21, 2015 12:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
