moving the stick?
Old Apr 23, 2009 | 08:58 AM
SJs 66coupe's Avatar
SJs 66coupe
Default moving the stick?
If I recall...there is something about if you use a 302 roller in a classic you have to move the oil dipstick but I haven't had any luck finding a "how to" article to do it.
Does anyone know where I can find one?
May have found a 302 roller that is freshly machined but it will need the stick moved....
Old Apr 23, 2009 | 09:28 AM
KMatch's Avatar
KMatch
http://www.midnightdsigns.com/Mustang/Engine.htm
Old Apr 23, 2009 | 11:48 AM
67mustang302's Avatar
67mustang302
Just put the early timing cover on it, and the dipstick goes in that. It also doesn't have provision for a mechanical clutch linkage, so you need to either get an adapter bracket or convert to cable/hydraulic.
Old Apr 23, 2009 | 05:45 PM
.boB's Avatar
.boB
Don't really need to. It will still fit in the side of the block, or the side of the pan.
Or you can swap front covers. If you do that, be sure and plug the hole in the side of the block.
If you swap the front covers, make sure the water pump matches the cover. Instead of swapping the front covers, you could just drill a hole in it.
Old Apr 23, 2009 | 08:15 PM
fakesnakes's Avatar
fakesnakes
This belief started due to the need to change the oil pan to a front sump pan for a classic Mustang requiring the dip stick to be moved to the timing cover.
CS2007
Jun 25, 2019 09:45 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
BeatnikFink
Oct 1, 2015 08:00 PM
wraith777
Sep 28, 2015 10:49 AM
