Timing Problem
Old Apr 26, 2009 | 01:53 PM
hbmustnag's Avatar
hbmustnag
Default Timing Problem
iput on a new edlebrock performance manifold and carb
and i am just not getting the torque i should be getting
and i know my timing is off
ive tried adjusting it but it doesn't seem to be getting that much better
suggestions?
Old Apr 26, 2009 | 04:17 PM
JMD's Avatar
JMD
Just not enough info to work with,,,
Have you put a timing light on the car?
Are you getting "as much torque" as you did before the swap or has your performance actually dropped from what it was prior?
And, exactly what parts did you put on? (Model and size).
Old Apr 26, 2009 | 04:19 PM
MIL1ION's Avatar
MIL1ION
2v = more torque at bottom end lower rpm
4v = more hp or performance at higher rpm
Old Apr 27, 2009 | 12:07 AM
Starfury's Avatar
Starfury
Not true at all, unless you're talking about a cleveland. A 4V carb (of the proper size) will actually get better low end throttle response than a 2V carb because the primaries on the 4V are smaller than the two venturis on the 2V. The smaller venturis result in a better vacuum signal and better fuel atomization, while the secondaries allow for increased breathing at higher rpm.
As far as the timing goes, you need to get yourself a timing light. Advance at idle with the vacuum advance disconnected and plugged should be 8-10*. Total advance (with the VA still disconnected) should be 30-35* all in by 3k rpm or so. You'll need a working tach to verify the latter.
Old Apr 28, 2009 | 06:47 AM
kalli's Avatar
kalli
yah. you need a timing gun where you can adjust the angle. I got one that does angles and shows rpm. i use that constantly. well worth the buy
Old Apr 30, 2009 | 10:23 PM
hbmustnag's Avatar
hbmustnag
we have tried the timing gun but the marks are on the timing wheel are not visible. i have tried cleaning it up but still no good, can't see em. i have tried doing it by ear but with not much improvment. and no i am not getting as much torque as before
hope this helps! and hope you can help me!
thanks
Old Apr 30, 2009 | 10:25 PM
hbmustnag's Avatar
hbmustnag
I have an edlebrock carb and manifold, pertronix ignition sysytem, new sparkplugs and wires, and a new air fliter.
carb is size is 650
Old Apr 30, 2009 | 10:32 PM
1slow67's Avatar
1slow67
ROTM Moderator
Take some white paint on a toothpick and put it in the slot on the harmonic balancer. That will make you able to see the mark when it is running.
Old Apr 30, 2009 | 10:44 PM
109jb's Avatar
109jb
thanks
You need to time it using the gun. If you can't see the timing marks on the balancer you will need to use a piston stop to determine TDC of the number one cylinder and then make your own mark on it. The piston stop is basically a bolt that screws into the spark plug hole. You rotate the engine BY HAND slowly clockwise until the stop contacts the top of the piston. Make a mark on the balancer at the timing pointer. Now rotate the engine counterclockwise until the stop contacts the piston. Make another mark. Remove the piston stop. TDC is half way between the 2 marks you made. Now go to an autp parts store that has tool loan and get an "advance" style timing light. This style will have a **** on it and a meter or similar and you turn the **** with the engine running until the meter reads whatever you want your timing to be. Now rotate the distributor until the TDC mark you made lines up with the timing pointer.
Old May 1, 2009 | 10:07 PM
mstg007's Avatar
mstg007
Thanks for the idea for the balancer for timing. I never thought you could do it! I might be doing that tomorrow!
