Edelbrock vs Weiand Intake
i'd stick with the 8124 as well. according to ford muscle magazine article that intake paired with a 600cfm edelbrock carb is giving the best performance out of the box.
important bit: out of the box. once you tune who knows what the best idea is.
how about that?
barry grant 525cfm road demonremanufactured 332.00$!
http://www.jegs.com/i/Barry+Grant/13...VFE-R/10002/-1
weiand 8124K
http://www.jegs.com/i/Weiand/925/8124K/10002/-1#
200$ including all gaskets bolts etc ... ?!
should be good :-)
what's your budget as I didn't see a cheap combo on summit
how about that?
weiand 8124K
should be good :-)
So is the Stealth too much for a Mild 351w? with a performer plus cam and headers? Im thinking about running a 600cfm edl. carb.. I saw in summit that it was reccomended for the larger displacement motors 350cid and higher..
These are what I found at Summit. There are a couple others under Intake/Carb combos heading.
Basically, pay for the intake and carb and get the gaskets, studs, air cleaner... for free.
http://store.summitracing.com/partde...8&autoview=sku
(Holley carb)
or
http://store.summitracing.com/partde...=128&N=700+115
Edelbrock carb
The guy who will help with the install seems partial to Edelbrock, so that counts for something.
(Holley carb)
or
Edelbrock carb
Yes, the Stealth is too much. There's no sense in running an intake that breathes better at high rpm if the cam and heads won't let the engine do that breathing. Intakes, like every other part of the package are some measure of trade off between low and high rpm power, but EVERYTHING in the engine package has to be matched for that trade off, like a chain an engine is only as strong as the weakest link.
Longer, smaller runners with a small plenum better time the intake pulses at low rpm's to help improve low end torque. They also provide better vacuum signal to the carb baseplate, improving throttle response and fuel atomization. Stock intakes are set up like this to maximize driveability, which usually means low-end torque and throttle response.
Shorter, larger runners with a large plenum allow the intake to flow more air at higher rpm's for better peak power, but the increase in runner volume results in poor intake pulses and poor vacuum signal to the carb baseplate at low rpm's. High rpm race engines will run funnel web intakes and the like because they spend most of their time at high enough rpm's to suck enough air through the intake to make use of the huge port runner volume.
Basically, there's one ideal configuration for runner length and diameter for any specific engine speed. Change the rpm, the ideal runner configuration is going to change. Many modern cars come with variable intake runner designs to optimize performance at both low and high rpm.
The air gap is a very nice intake and a step above the stealth, it will flow better up top.
the problem is who ever sticks with the same setup for 15 years? Most get the HP bug and continue until the money runs out, so they always want the best bang for there buck and will do good in the long haul. Most start with a intake carb upgrade, then move to exhaust and headers. After that they might do heads or cam and then it turns into the entire motor.
It affects velocity as well. You move the same amount of air through a larger opening(bigger runners) and the velocity drops off, less velocity means the charge has less inertia to get into the cylinders with, volumetric efficiency drops off and power along with it. There's a reason that n/a drag cars run tunnel rams and stock carb'd cars run low rise dual planes.
It's not a matter of which intake flows better, it's a matter of which intake will fill the cylinder better within a given rpm range.
