Pertronix Questions
Old May 7, 2009 | 05:00 PM
fishkg's Avatar
fishkg
I have the Igniter II and the flame thrower coil. It made a big improvement. I decided to bypass the pink resistor wire by running a direct wire parallel to it (but left the pink resistor wire in place). That way if the Igniter module ever does have a problem, I can swap the old coil and points back in, and clip the bypass wire to let the resistor wire do the work.
I also went to low resistance plug wires to get more power to the plugs.
Old May 7, 2009 | 05:23 PM
flickjo68's Avatar
flickjo68
I just ordered the Ignitor 2 ignition and the flamethrower 2 45,000 volt coil last night so hopefully it'll get here this weekend and i can put it on. I'll let y'all know if i see any difference.
Old May 8, 2009 | 04:22 AM
kalli's Avatar
kalli
that's exactly what I have. before you bang it on make sure the screw for the vacuum canister is tight (so the vacuum canister doesn't rattle). Will cause all sorts of problems. Other than that I love it.
Old Jun 27, 2009 | 05:51 PM
Houndstooth's Avatar
Houndstooth
So did you get it installed? What do you think? I am just about to order the Ignitor III because CJ Pony Parts is having a sale. I think it's about the same as the II except it has a rev limiter.
Old Jun 27, 2009 | 08:59 PM
flickjo68's Avatar
flickjo68
Yes, I got it and i put it in. It was one of the easiest things I have done to the car. I bypassed the resistor wire and just ran a new wire from the ignition. I noticed that the car runs smoother and may have a little more power. I plan on opening up my spark plug gap a little bit and may see a little more improvement when I do that. I would say that it is worth it if it's on sale.
Old Jun 27, 2009 | 11:32 PM
Houndstooth
Thanks for the info, I just ordered it.
Old Jun 28, 2009 | 02:43 PM
Carlos Pineiro's Avatar
Carlos Pineiro
I have Pertronix Ignitor II and flamethrower coil and it's great. I can't see anyone ever going back to points again.
CP
Old Jun 28, 2009 | 05:07 PM
1965fastback's Avatar
1965fastback
You will see a difference in idle quality and the way it starts. With the ignitor and stock coil on my 200 it starts and idles great!
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
