Toploader Hydraulics now Available!
Old May 7, 2009 | 02:32 PM
AmericanPowertrain's Avatar
AmericanPowertrain
Former Sponsor
Default Toploader Hydraulics now Available!
We have finally added a Toploader hydraulic system to our line of HYDRAMAX Hydraulic systems. Up until now we had to use a very expensive bearing that made the kit too pricey. But our engineers have gotten their heads screwed on tight and we are now shipping our first complete kits for the 1-1/16" x 10spline Toploaders. A new steel bearing retainer (not a cheesy plastic base) is included but is not shown in the image. We are working to get this updated.
Give us a call if you need to get rid of your cable or mechanical linkage, or just want smoother clutch operation.
Old May 7, 2009 | 03:58 PM
racin66coupe's Avatar
racin66coupe
whats the pricing on this kit?
Old May 7, 2009 | 04:02 PM
urban_cowboy's Avatar
urban_cowboy
Webpage says
Hydraulic version is $599.
Cable version is $329.
Old May 7, 2009 | 04:04 PM
racin66coupe
yeah, i just looked at the webpage. duh, coulda done that BEFORE asking
Old May 7, 2009 | 04:07 PM
urban_cowboy
Hahaha...BRING ME INFORMATION NOW!!!
Old May 7, 2009 | 04:09 PM
AmericanPowertrain
Former Sponsor
Default Pricing on HYDRAMAX
The price for the complete kit is $599 and includes the following:
HYDRAMAX adjustable firewall bracket (patent pending)
Low Profile Master Cylinder
Reservoir Kit with optional local or remote reservoir
Braided Steel Supply and Bleed Line
Custom Toploader Steel Bearing Retainer
Hydraulic Release Bearing
Pedal Specific Clutch Rod
Stainless Heim Joint with Carbon Fiber Race
Hardware Kit
All Fittings
Complete Installation Instructions
24/7 Customer First Tech Support
We will offer a $40 discount to Mustang Forum Members who supply a screen name when ordering. We also have these kits for the TKO, T5 and T56.
Let me know if you have any more questions, or give us a call at 931.646.4836. My extension is 103.
Last edited by AmericanPowertrain; May 7, 2009 at 04:11 PM. Reason: highlighting discount
Old May 7, 2009 | 04:13 PM
racin66coupe
sorry im so new to this, but would this get rid of the clutch fork?
and urban, prettymuch :P haha jk i actually forgot they had a site
Old May 7, 2009 | 04:17 PM
AmericanPowertrain
Former Sponsor
Default Hydraulic Clutch: No fork
Bloody newbies Yes, you are correct, you will get rid of all of the mechanical linkage including the fork and the mechanical throw out bearing. You will have a concentric release bearing, which looks like a throw out bearing on the front of the transmission, but works like a brake caliper. Fluid goes in, bearing is extended and pushes directly on the fingers of the clutch. Just like a caliper extends and presses on the brake pads when you put fluid in. HYDRAMAX also has the only integrated pedal stop available, which limits pedal travel so just enough fluid reaches the slave bearing without damaging the seals. Hope this helps. Gray
Last edited by AmericanPowertrain; May 7, 2009 at 04:20 PM. Reason: more info needed
Old May 7, 2009 | 04:19 PM
racin66coupe
Originally Posted by AmericanPowertrain
Bloody newbies Yes, you are correct, you will get rid of all of the mechanical linkage including the fork and the mechanical throw out bearing. You will have a concentric release bearing, which looks like a throw out bearing on the front of the transmission, but works like a brake caliper. Fluid goes in, bearing is extended and pushes directly on the fingers of the clutch. Just like a caliper extends and presses on the brake pads when you put fluid in. Hope this helps. Gray
huh, thats interesting, and very cool. ill definatly keep this in mind for when i do my swap to toploader. if i have the money at the time
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
uberstang1
Sep 20, 2015 06:42 PM
Mikett
Sep 12, 2015 10:52 PM
whatsup62
Aug 29, 2015 01:25 PM
