No Spark
Old May 14, 2009 | 01:34 AM
knuckless's Avatar
knuckless
Default No Spark
So i just fixed my motor mount and i was taking the car for a drive around the block to check that the motor mount was good now. and in the middle of the drive at 40mph or so the engine just stalled and shut off as if i turned the key off. i pulled over and tried starting it back up and the starter was engaging and cranking the engine but i was getting no spark.
i checked my coil and its good
wires are new
checked the distributor cap and rotor inside
what else could be causing my engine to not get spark
Old May 14, 2009 | 02:11 AM
Starfury's Avatar
Starfury
How do you know it's not getting spark? That's not something you can hear. Also, how did you check your coil?
Old May 14, 2009 | 02:25 AM
knuckless's Avatar
knuckless
well yeah its not something i can hear
i pulled my plugs out to check and wasnt getting any spark
i have a coil in my garage that used to be on my car before i upgraded the ignition. so i just plugged in the old coil to see if that would get it going. didnt work so i know its not the coil
Old May 14, 2009 | 02:37 AM
Starfury's Avatar
Starfury
Did you ground the spark plugs while you were cranking? No offense, I just want to make sure it actually is a no-spark issue, and as a tech you have to start from square 1. A lot of people will say "I'm getting no spark" just because the engine turns but doesn't start.
Are you running points or electronic ignition?
Assuming you're getting no spark, you need to check voltage at the coil+ terminal with the key on. If not, something's wrong with your wiring to the coil. If you do have voltage there, check your distributor innards (points or electronic) and make sure everything's grounded properly.
Old May 14, 2009 | 10:11 AM
knuckless's Avatar
knuckless
yeah i grounded it to the block when cranking the engine from the solenoid. its ok i didnt provide much info to saying im getting no spark. its electronic ignition and i tried using my voltage meeter but the batteries corroded over and i gotta clean it up
Old May 14, 2009 | 10:41 AM
67mustang302's Avatar
67mustang302
Sounds like an ignition wiring issue somewhere. There's an open connection, loose ground, bad terminal....something. Trace out all your wiring and use a voltmeter to run a continuity check on all the wiring and terminals.
Old May 14, 2009 | 11:11 AM
kalli's Avatar
kalli
if you have a voltmeter check if you have 8V (12V) on coil+ against battery minus when key is in ignition position. If not then that is your problem.
if not check if the cables are properly attached to ignition module and coil.
If you have pertronix ignition check if the vacuum canister rattles (if you can move it). If it does then this is your problem as the ignition module uses the ground of the screw that holds the canister. In my pertronix this came loose-> no ground->no spark
since you haven't changed anything you can always try to run a cable from battery+ directly to coil+ and see if the car starts. If it does switch off and remove cable immediately. Do NOT run the car that way. it's just a troubleshooting step
Kalli
Old May 14, 2009 | 02:25 PM
knuckless's Avatar
knuckless
i fixed my voltmeter and check to see if i had power to the coil, which i didnt so i traced the engine gauge feed harness and it was frayed behind the head cover.
picked a new one up and im good to go, its always something dumb with my wiring
Old May 14, 2009 | 06:44 PM
Starfury's Avatar
Starfury
Glad you figured it out Bet you're happy you have a working voltmeter now, aren't you?
Old May 14, 2009 | 09:10 PM
knuckless's Avatar
knuckless
yeah thats helped me countless times, i always over look the little things and think its something worse
