Finally PROGRESS!!
Old Jan 26, 2014 | 04:59 PM
  #111
90RunnerRed's Avatar
90RunnerRed
More progress today, alternator installed and wired up:
Crank pulley and Radiator in place. Fuel line is also mocked up. I need to get one of the 90 degree banjo fittings for the carb to make the install a little cleaner:
Old Jan 26, 2014 | 05:06 PM
  #112
90RunnerRed
Z bar installed and hooked up, you can see in the second picture that the adjuster rod is at a slight angle. I can't figure out why. The engine's centered in the bay and the zbar lines up well with the clutch rod. It feels good when you actuate the peddle. I had the wife push the peddle while I watched it and it seems to work. Perhaps my OCD is just kicking in:
Old Jan 26, 2014 | 05:23 PM
  #113
90RunnerRed
Parking brake hooked back up:
Old Feb 9, 2014 | 12:35 PM
  #114
90RunnerRed
I didn't want to route the PCV hose to the front of the edelbrock, so I found a fitting for the back:
PCV Hose installed:
Old Feb 9, 2014 | 12:37 PM
  #115
90RunnerRed
Unfortunately the posts on the new coil wasn't tall enough to have both the petronix wire and the switch wire on it with the OEM style connector for the switch wire so I had to put a new connector on, but it doesn't look too bad with shrink wrap in place:
Old Feb 9, 2014 | 12:38 PM
  #116
90RunnerRed
Thermostat housing, hoses, and fan all in place:
Old Feb 9, 2014 | 12:41 PM
  #117
90RunnerRed
And finally, after a short stint with being a tooth off on the distributor and a little trouble getting the air out of the fuel line, she's running!!! (She's a little loud because all I have on there right now is the H pipe):
<iframe width="560" height="315" src="//www.youtube.com/embed/6acGdcRmQDA" frameborder="0" allowfullscreen></iframe>
Old Mar 3, 2014 | 01:09 PM
  #118
Adrenolin's Avatar
Adrenolin
Coming along nicely
Old Mar 3, 2014 | 07:34 PM
  #119
90RunnerRed
Thanks! Ran into some issues with it running really rich. Pretty much expected that given the altitude here. I put new jets in this weekend and the car is running great. Took it for a 15 mile drive yesterday and forgot how great the car is to drive. Got back home and went to put it in the garage and the radiator was spewing fluid. A little disgusted at this point, because this is actually the second radiator since I put it back together. Had the original (non-leaking) rebuilt, it leaked, put a parts store radiator in, and now it's leaking!!!
Ordered a Champion aluminum radiator yesterday with shroud and efan. Hopefully this is the last iteration.
Old Mar 3, 2014 | 11:04 PM
  #120
ProblemHouston's Avatar
ProblemHouston
I'm going to get under my car this weekend and see what it looks like against what I see here. Very clean, your car looks great. Thanks for the help
