T5 Swap and Speedo is off
Old May 27, 2009 | 02:57 PM
AscolA's Avatar
AscolA
Default T5 Swap and Speedo is off
Hi Guys,
Just got did a T5 swap on my 68 coupe. Anyway I ordered a new little gear thingy and don't know were to swap it into. Any help would be great.
Thanks
Old May 27, 2009 | 03:03 PM
remicks's Avatar
remicks
A speedo gear? If that is what you are talking about look on the driver side of your trans and there should be a black cable, the speedo cable, going into the side on the top. Unbolt that and pull it out and the gear will be attached to the end, replace that with your new gear.
Old May 27, 2009 | 03:08 PM
fakesnakes's Avatar
fakesnakes
When you remove the old gear, compare the two and make sure the teeth cut is the same (angle of the gear teeth are in the same direction). There are two different types, one made for the passenger side and one for the driver side. You do not want to mix them up!
Old May 27, 2009 | 03:13 PM
AscolA's Avatar
AscolA
Man you guys are fast!
Thanks for the info. I'll let you know if I have any more questions.
Thanks again!
Old May 27, 2009 | 03:23 PM
remicks's Avatar
remicks
Yeah, mixing them, that would be slightly bad.
What color gear is the gear you ordered, the one in the trans and what is your rear gear ratio?
The color will let you know how many teeth the gear has and will allow you do the math to figure out what you need to get your speedo as close as you can.
After I did my t5 swap the 3 speed's old yellow gear, I don't remember how many teeth, worked for me because it worked with my 2.79 rear gear ratio. I know the NPD catalog has the formula and gears so you can figure out if you have what you need or need to order a different one.
Old May 27, 2009 | 05:31 PM
AscolA's Avatar
AscolA
I ended up getting a black gear. My gear ratio is 3.50.
Old May 28, 2009 | 01:48 AM
tx65coupe's Avatar
tx65coupe
My Mustang has a T5 as well and my ratio is 3.50 and I have a pink speedo gear. Mine reads about right. The black gear I think will make it read slower.
Old May 28, 2009 | 02:13 AM
stangtjk's Avatar
stangtjk
your tire diameter will effect this also. I just was looking at a calculator that took all that stuff into account and gave you what gear you needed but i dont remember where i saw it.
Old May 28, 2009 | 02:22 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
depending on what year car the t5 is from will depend on the color gear you need
1986-89 t5 as follows:
gears
3.08 18tooth
3.27 19tooth(pink)
3.55 20 tooth(black)
3.73 21 tooth(red)
4.10 23 tooth(white)
1990-93 t5s
gear ratio
3.08 20 tooth(black)
3.27 21tooth(red)
3.55-4.10s gets a 23tooth(white)
Old May 28, 2009 | 02:34 AM
tx65coupe's Avatar
tx65coupe
I have the Tremec T5 from Summit. I have 235 60 15 rear tires as well. Maybe that is why the pink gear works for my setup.
If you have a smaller tire then the black gear may be right for your setup. What size tires do you have?
