Automatic Choke Troubles
Old Jun 1, 2009 | 08:27 AM
ChesterKaup's Avatar
ChesterKaup
Angry Automatic Choke Troubles
I am working on a 1966 mustang 289 with a ford 2100 carburetor. I have replaced the 2 choke tubes, choke stove pipe fitting and screen and rebuilt the carburetor. No hot air is getting pulled up to the choke housing. Should I get a vacuum reading if I hook a guage to where the choke tube connects to the choke housing? Is there someting maybe I did wrong rebuilding the carb?
I noticed in the carb kit there were three different gaskets for the choke coil; on was a donut, one was mostly solid with a curved cutout for the choke coil spring arm and had 2 small holes, the third was like the second except had just one larger hole. I used the donut shaped one. Is that correct?
Old Jun 8, 2009 | 04:53 PM
ChesterKaup
I have since found 2 potential causes of the problem. Despite soaking the carb in carb cleaner the passage from the choke tube into the choke housing appeared to be plugged with black crud. Removed it. Second potential problem was a poor seal where choke tube attaches to the choke housing. Unfortunatly threads on choke housing are bad. Will proably have to get another one.
Old Jun 8, 2009 | 08:32 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
The heat element in the stove itself may be clogged too.
Choke Stove rebuild.
CS2007
Jun 25, 2019 09:45 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
ChampInSD
Oct 2, 2015 04:55 AM
wraith777
Sep 28, 2015 10:49 AM
