vacuume help
Old Jun 21, 2009 | 04:45 PM
lilrobo's Avatar
lilrobo
Default vacuume help
what is the vacuum on a 65 mustang coupe,,, i have about 15 .. we are having trouble with our new disc brakes that we installed on front ,, and we did a line lock too ,, it holds but now what we was thinking ,, and we was thinking that we would have some locking up either with front or back,,, we did install a proportional value also for the rear , we could see a small difference in adjustment ,, so anyone got anything to ad to help with this
Old Jun 21, 2009 | 08:09 PM
MIL1ION's Avatar
MIL1ION
Old Jun 21, 2009 | 08:37 PM
lilrobo's Avatar
lilrobo
well i played with timing, but didnt mis with the air mixture,, i will .... but it looks like about 19 to 20 so i am not far off ,i do know the motor is fine off a over haul maybe 2 years back so i will check air mixture
thanks
Old Jun 21, 2009 | 09:40 PM
Starfury's Avatar
Starfury
That chart is not always correct. Good start, but a cam with a lot of valve overlap doesn't follow the normal rules.
That said, if you've got 19-20" at idle, you've got more than enough to work the power booster (and don't have a super aggressive cam). Did you bed the pads properly after installing them? Do you have the right m/c for the setup?
I have OE 4-piston non-power discs on my '67 and I can lock them without much problem. You shouldn't have any problem at all with a power booster.
Old Jun 22, 2009 | 04:53 AM
lilrobo's Avatar
lilrobo
well we think so,, there is a small cam too but all we have is 15 ,, we put 13" rotor cobra disc on the front with a line lock we first had the line lock hooked up wrong we think its right now you can tell it holds , but not locked up ,, and going down the road it wont lock up either the front or the back ,, now the MC i guess its the right one we got it from a mustang dealer its a power MC duel rev ,,, does it matter about bleeding with it running or not cause of power brakes ????
we are going to try to bleeding again with a hose and jar or fluid
so we will see
thanks
Old Jun 22, 2009 | 11:39 AM
Starfury's Avatar
Starfury
Bleed with the car off.
How did you bed the pads?
Old Jun 22, 2009 | 06:46 PM
lilrobo's Avatar
lilrobo
we blead with car off this time using the hoses to a jar and it seems better ,, we haven t done anything with pad how should we do the pads as far as bedding them in ??
Old Jun 22, 2009 | 08:40 PM
Starfury's Avatar
Starfury
Carefully get yourself to a straight section of road with no traffic. Get up to 20mph and quickly brake to ~5mph. Don't stop and don't lock up the brakes, but get down to 5mph as quickly as possible. Get back up to 35mph and quickly brake down to 5mph again. Get up to 50mph and brake down to 5mph. Get back to your garage with as little braking effort as possible and allow the brakes to cool down.
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
Ipaman
Sep 22, 2015 07:01 AM
SteelerNation82
Sep 16, 2015 07:11 AM
TfcCDR
Sep 14, 2015 12:08 PM
