Valve Cover Gasket Installation
Old Jul 20, 2009 | 02:38 PM
unit91's Avatar
unit91
Question Valve Cover Gasket Installation
Should both sides of the gasket be oiled before installing?
Old Jul 20, 2009 | 02:41 PM
Canary94GT's Avatar
Canary94GT
I don't oil it, but I apply some silicone gasket sealer to only the side that attaches to the valve cover.
Old Jul 20, 2009 | 04:03 PM
RagHead's Avatar
RagHead
Apply some gasket sealer to the side that going to the valve cover, no oil on either side.
Old Jul 20, 2009 | 04:18 PM
coda618's Avatar
coda618
No oil or sealer. I have seen people using gasket adhesive against valve cover to hold it in place, but that is what the tabs are for. I install dry. If you are careful and torque the VCs to correct specs, you should not have a problem. Most leakage comes from overtightening the VC bolts and warping the VC.
Old Jul 20, 2009 | 04:20 PM
Starfury's Avatar
Starfury
True, but how many stamped steel vc's have you seen that haven't been overtorqued at some point in their life? I'd use some Ultra Black on the vc side to be safe.
Old Jul 20, 2009 | 06:40 PM
unit91's Avatar
unit91
what's ultra black???
Old Jul 20, 2009 | 06:56 PM
Gun Jam's Avatar
Gun Jam
a brand of black silicone made by permatex.....
-Gun
Old Jul 20, 2009 | 07:10 PM
JamesW's Avatar
JamesW
The new metal framed gaskets are super. they have a metal core and bushed holes so that you can tighten down snuggly and not worry about leaks.
They are reuseable too. No sealer needed.
Old Jul 20, 2009 | 08:40 PM
lawman65's Avatar
lawman65
I torqued mine down by feel with a dry cork gasket and no leaks whatsoever.
Old Jul 20, 2009 | 09:33 PM
Adrenolin's Avatar
Adrenolin
I agree. The Ultra Black by Permatex is great stuff.
I'm dropping my VCs off tomorrow to have a set of 1/2" aluminum spacers cut due to the rockers being too high and hitting the baffles. I'll have to use an upper and lower gasket on each side and the Ultra Black will definitely be used. That said the water cutter at a local CNC shop is an amazing machine!
