Guys w/T5
Old Jul 22, 2009 | 03:27 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Guys w/T5
I just fixed my T5 and need to fill it with transmission with fluid. I've read that some use ATF and others use MTF. I have an 85 world class T5 and don't know what to fill it with. I bought MTF before I rebuilt it and then read some need ATF. Does it really matter?
Old Jul 22, 2009 | 04:02 PM
TexasAxMan's Avatar
TexasAxMan
Yes it matters. ATF for a world class. Do not put gear oil in it or it will fail.
BTW, what was the problem? You said yesterday that it wouldn't spin.
Old Jul 22, 2009 | 05:43 PM
1slow67's Avatar
1slow67
ROTM Moderator
I put 5th gear in backwards
Old Jul 22, 2009 | 06:04 PM
Starfury's Avatar
Starfury
hehe. Least you figured it out
Old Jul 22, 2009 | 06:37 PM
1slow67's Avatar
1slow67
ROTM Moderator
I need some bolts for my shifter, 1 for my bearing retainer and 1 for the tailshaft. Would anyone know where I can buy them?
I went to lowes and bought some, but they don't fit. I only have 1 bolt to bolt on my shifter to the tailshaft. I'm missing 1 bolt on the bearing retainer, and I need a new bolt to bolt the tailshaft to the main part of the transmission.
Old Jul 22, 2009 | 07:51 PM
Starfury's Avatar
Starfury
It's nothing special, just a bolt. Go to a real hardware store (Ace, OSH, etc) with the one bolt you have that works and get 3 more.
Old Jul 23, 2009 | 03:06 PM
1slow67's Avatar
1slow67
ROTM Moderator
Autozone FTW! They allowed me to get store credit without a reciept on my MTF. Also had the bolts I needed for my T5. I'm glad they have the display out where you can screw in your bolt to find out what size to buy. Also got 3 qrts of transmission fluid.
I don't dislike any other auto parts store, just go to autozone a lot.
Old Jul 23, 2009 | 10:53 PM
1slow67's Avatar
1slow67
ROTM Moderator
Anyone on her have a 67-70 T5 crossmember they would sell me for under $100? There is a guy on another forum that has one cheap, but he hasn't been on since the 16th and I would like to buy one so I can get it next week.
Old Jul 23, 2009 | 11:21 PM
Starfury's Avatar
Starfury
Check out the Corral Forums classifieds. I've heard (but can't confirm) that the adaptor crossmember is identical to those used in fox body cars.
Old Jul 24, 2009 | 12:28 AM
67mustang302's Avatar
67mustang302
If you have a manual tranny that uses ATF spec fluid, then get the GM Synchromesh. It's primarily used in the TREMECs, but it's designed for ATF spec manual gearboxes. It's around $17 a quart but it's some badass gearbox fluid.
And yeah, go to a real hardware store to get hardware, and just buy grade 8 or stainless.
