Quarter Panel Extension Molding question
Old Jul 22, 2009 | 07:37 PM
NvrSumR's Avatar
NvrSumR
Default Quarter Panel Extension Molding question
Has anyone else run into this problem? There's not enough room to get the nut on the bolt. Should I just drill the hole out enough to get the nut on?
Oh and I finally completed my engine and tranny swap, after 5 years. Pics and a video to come soon.
Old Jul 22, 2009 | 10:19 PM
NvrSumR's Avatar
NvrSumR
Anyone?
Old Jul 22, 2009 | 10:29 PM
Tony R's Avatar
Tony R
you could pull the studs out and get a longer ones or turn them into bolt. Are these after market end caps? The ones I received on my fiberglass end caps are way too long.
Old Jul 22, 2009 | 10:38 PM
NvrSumR's Avatar
NvrSumR
This is the kit I got from Johns Mustang. The bolts slide into the molding on each end.
Old Jul 22, 2009 | 11:32 PM
Tony R's Avatar
Tony R
My bad. I read it wrong. I thought you were dealing with end caps. Have you tried to contact the distributor and explain that their studs are too short. I could come up with some redneck fixes but I would try to contact johns first. Might be able to find some longer bolts at a hardware store.
Old Jul 23, 2009 | 07:45 AM
NvrSumR's Avatar
NvrSumR
Good thinking, I hadn't thought of that yet.
Old Jul 23, 2009 | 08:25 AM
zmetalmilitia's Avatar
zmetalmilitia
You may have to rig some longer bolts somehow. This is why I hate buying aftermarket garb. You think if they are going to reproduce an item, they would get it right.
Old Jul 23, 2009 | 09:11 AM
boogerschnot's Avatar
boogerschnot
Those are the plastic type studs arent they? The ones with the little spring clip like the original would fit. You can buy a pack of them usually at Napa..
Old Jul 23, 2009 | 01:24 PM
NvrSumR's Avatar
NvrSumR
I tried Johns Mustang and got nowhere, maybe it was because I could barely understand his accent. Anyway, I'll try a few stores to see if they have anything simular. If I can't find anything I may just have to drill the holes out to fit the nut.
chrisdbassplayer
Oct 13, 2015 06:53 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
treesloth
Sep 28, 2015 07:03 AM
2k232
Sep 16, 2015 10:28 AM
