Funky six problem, occaisional missfire or backfire?
Old Jul 27, 2009 | 09:01 PM
EZFEED's Avatar
EZFEED
Default Funky six problem, occaisional missfire or backfire?
Got the buddys 68 200 I6 back together and vacum plumbed right. Retimed it too but still have a strange problem.
At idle the engine has a random slight missfire or backfire. The carb is one of those new "professional" rebuilds that he ordered. The distributor is new and even swapped it out with another to see if that was the fault but it ran the same. All plugs are firing correctly, everything seems cool but somehow it gets this random pop?
Old Jul 27, 2009 | 09:19 PM
1slow67's Avatar
1slow67
ROTM Moderator
Mine does it and I am used to it.
Old Jul 27, 2009 | 10:25 PM
EZFEED's Avatar
EZFEED
I know allot of them do, mine however does not and its so quiet you can almost not hear it so I know it can be remedied.
I just wonder what the heck it could be?
Old Jul 27, 2009 | 10:39 PM
Canary94GT's Avatar
Canary94GT
Hmm mine doesn't do anything like that at idle.
Have you replaced your fuel filter? Is it dirty? Backfiring can be caused by low fuel pressure.
Old Jul 27, 2009 | 10:40 PM
1slow67's Avatar
1slow67
ROTM Moderator
Does it have an aftermarket muffler? My grandfathers stock exhaust doesn't do it, but my no restriction exhaust does.
Old Jul 27, 2009 | 10:49 PM
EZFEED's Avatar
EZFEED
Pretty sure his filters are clean, I will have him buy a new one just to check.
Now his exhaust system isnt factory........low backpressure may indeed be a reason although I dont see how.
Old Jul 27, 2009 | 10:57 PM
1slow67's Avatar
1slow67
ROTM Moderator
Fuel filter isn't it. I just replaced mine last week.
I don' know how it would, but it could be possible. I have a straight through style muffler on mine and that is the only exhaust mod. I don't know when mine started the popping noise though.
Old Jul 28, 2009 | 01:42 AM
kalli's Avatar
kalli
buddy of mine's 68 with a 289 does the same (at least it fits your description).
since it's a V8 and it's got straight through pipes without crossover, it was easy figuring it was coming off the left pipe (driver side).
When I pull #7 cylinder on that one it stops. drove me freaking insane as I changed plugs and cables, seperated them thinking it was crossfiring. I can't get down to it
just as you describe it the occasional pop ---- pop-pop -------------pop ...
Another thing I figured is that even though idle mixture is correct it makes this typical load poppiong on deccelleration that indicates to lean (at least in my experience), but I couldn't find any leaks
Old Jul 28, 2009 | 01:55 AM
EZFEED's Avatar
EZFEED
Maybe your valves were leaking in that cylinder. Did you do a compression test on that cylinder to see what was up?
Now this is wild and you'd think it impossible but I have had it happen......the plug may have not been grounding on that cylinder too. Might try hitting it with some brake parts cleaner.
Old Jul 28, 2009 | 09:15 AM
SJs 66coupe's Avatar
SJs 66coupe
I don't know how to fix it but if it makes you feel any better my 289 does the same thing.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
