Under Fender bolt locations on 69 coupe
I am in need of information concerning type of bolt, and assembling lower part of fender to the car for a 69 coupe. It was removed a while ago and I thought that I could remember how to re-install it. I hope i'm not the only one who does this! Does anyone have a diagram that they could send out.
Thanks for your help.
I don't understand the question... under the fender I know on one part there is a threaded "L" bracket, one end bolted to the cowl/inner fender area, other to the bottom of the fender. I believe there is one more spot that you bolt straight to the underside of the car.
This is just off of memory though, you should be able to see the holes in the body for the bolts to go, one for the "L" bracket, other straight to the fender (I believe). The front part of the fender is bolted to the front valance.
As for the type of bolt... it was a standard 1/2" hex bolt with coarse threads I believe, it's the same as the bolts that go along the top of the fenders.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
