Smooth front bumper bolt removal?
Old Aug 20, 2009 | 11:06 PM
67mustangreg's Avatar
67mustangreg
Default Smooth front bumper bolt removal?
My car came with HALF a front bumper. Why? I have no clue. But it did, now as I begin to actually make something of my paperweight I need that bracket before i toss the bumper. So, I went to take it off the other day. But the thing is, is that there's nothing to hold on to so it just spins around with the nut. I already gave it a little penetrating oil. How do I get the bracket off without drilling out the nuts? That would suck, and barely be worth the $10 for a new one.
Just an idea of what I'm working with here, my car in it's current state:
Old Aug 20, 2009 | 11:38 PM
andrewmp6's Avatar
andrewmp6
You could just cut the head off the bolt.
Old Aug 21, 2009 | 12:03 AM
67mustangreg
Yes, I thought about that. But a NEW bracket from my local mustang shop is only like $10 bucks. This was my high school project, even though I just graduated, and I've done everything on it as inexpensive as I can and all by myself too. No shops have touched her yet, under my ownership. If I can, I re-use as many of the old parts as I can. I just resurface them and hit them with primer or new paint. It just seems like a waste to buy a new one.
Old Aug 21, 2009 | 12:14 AM
Canary94GT's Avatar
Canary94GT
The bumper is not warped or anything? Cause if it is, the bumper support might be also. Just a thought.
Old Aug 21, 2009 | 12:20 AM
67mustangreg
A lot of the crap on my front end is warped. I have suspicions it was in a low-speed accident...I was working on flattening the grill out today with a mallet and brick. It's really messed up and I don't dee how it's fixable. But I'm not going to spend $70 for just a freakin' piece of metal. I thought it was usable, same thing with the driver's "grille opening panel"...it's pretty warped...not sure what to do now, I have a repro body assembly manual on order from my shop that should be in tomorrow. I've been buying all the parts to put the whole front back together...bought a front bumper, the front valance, brackets etc etc etc...and now I may get held up by the darn grill not fitting right. I'll get more pics tomorrow to explain what I'm talking about.
Old Aug 21, 2009 | 06:31 AM
ThanksDad's Avatar
ThanksDad
Try to find a "Nut Breaker" . It's a small tool that goes around the nut, it has a threaded point that is supposed to split the nut. Do a Google search for Nut Breaker and you can see one. http://www.tool-home.com/products/ca...ducts_id=16337
Old Aug 21, 2009 | 11:21 AM
Tony R's Avatar
Tony R
thanksdad has the right idea. You may be able to borrow one from a schucks or napa. I think Harbor Freight sells them cheap as well. You may have to replace the bolts any ways. IIRC the bottom of the head has a square spot that goes into a square hole in the bumper and if the one on the bolt is bad then you may not be able to get the bolt tight enough on the new bumper.
Old Aug 21, 2009 | 12:33 PM
HGC's Avatar
HGC
Those bolts are supposed to be squared under the head and fit into a squared hole, which holds them in place. Something is not right with your bolt or hole.
Old Aug 21, 2009 | 01:36 PM
jcoby's Avatar
jcoby
you used a brick as a dolly? seriously?
Old Aug 21, 2009 | 04:43 PM
groho's Avatar
groho
use a rust penetrating oil, and grab the end of the thread with vice grips. Then break the nut loose. Once you're done, use a tap/die set and clean the threads up. Otherwise, weld the head to the bumper with a couple tac welds that can be cleaned up after your done.
