347 engine questions
Old Aug 29, 2009 | 06:24 PM
topspeed1's Avatar
topspeed1
Default 347 engine questions
I just purchased a 1969 correct craft mustang ski boat. The boat originally came with a reverse rotation 289. Being reverse rotation the engine has to be flat tappet. I am building a 347 with gt40p heads to replace the 289. My question is a 350hp goal reasonable for a gt40p flat tappet 347.
Old Aug 31, 2009 | 02:26 AM
67t5ponycoupe's Avatar
67t5ponycoupe
It sounds like a reachable number with a stroker motor. I would think the cam you select would be critical. I have no idea what would be a good cam to run for your application.
Old Aug 31, 2009 | 01:49 PM
67mustang302's Avatar
67mustang302
Get a custom ground roller cam, they should be able to set one up for reverse rotation. And yes, it should be able to make 350hp easily, probably around 5,500rpm or possibly lower depending on the setup.
YoungStangsMan
Sep 5, 2015 07:01 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
