How do I get rid of paint overspray from spray can?
I was doing some touch up painting on a small spot on my hood with a spray can. I didn't cover enough of the hood (lazy I guess). Some paint sprayed on the good shiny paint. How do I get rid of paint over spray from spray can?
I'd try some regular wax first, sometimes it makes overspray release, if not I'd step up to a mild compound then up from there if needed. Others may have better chemical ideas.
Jon |
I'd use a small amount of paint thinner on a rag and work fast. The fresh paint should come right off before the thinner has a chance to eat into the older paint. The tricky part is when you get close to the touched up area.
Use a very fine polish, "swirl remover". It'll come right off, and look better than before. Ask me how I know. :icon_doh:
A "cleaner wax" ought to work.
Norm |
if you have a buffer buff first, then go to a reducer wipe then wipe dry if that doesnt work move to thinner.
if the above doesnt work, use some 2000 grit paper wet sand and buff back |
Clay bar will take it right off without any worries about hurting the paint.
Several Ideas Worked
Hey thank you all for the ides. Several of the ideas worked. I tested different concepts on various parts. The paint thinner worked great. The wax cleaner worked too. The sandpaper worked (I used 1000 that left a mild scratches that came out with the wax cleaner). I also used clay bar. That worked too.
That is what I love about Mustang Forums. You get some great advice when most needed!
Still have scratches from the 1000 grit sandpaper
I still have scratches from the 1000 grit sandpaper. So, don't do that. How can I get these scratches out? It may just be to the clear coat. Can I use wet sanding with say, 2000 grit?
