high beam not working
Old Sep 18, 2009 | 12:50 AM
MetalEd's Avatar
MetalEd
Originally Posted by OCHOHILL
You will also need wire stripping/crimping tools, 25ft of red 14 gauge, 25 feet of green 14 gauge, 25 feet of black 14 gauge and 10 feet of red with an inline fuse. Don't forget to run good grounds for you circuits. Electricity has to form a loop to work.
Don't use the cheap wire crimpers that come with most automotive crimp sets, they are basically a pair of thin pliers and most people think they are useless and create inferior crimps. Many pro electronic shops sell pro crimping tools for $150-$200, but I found a really good set at pep-boys for $30. I was really amazed to find them at this price and thought they must be cheap knock-offs, but they are really good quality and work perfectly!
It really does make a difference! It is a ratcheting crimper that has adjustable tension setting and creates an interlocking dual crimp like you will see on most stock automotive wire crimps.
As an example, Here's a pair on Amazon for $25, they have ton's a different brands. (I don't know/endorse these vendors)
http://www.amazon.com/0380PT-22-10-R.../dp/B001QRW20W
Here's a page that has info about headlight relay install Using these crimpers. it's an MGB page, but has the headlight relay info and shows the difference between the two types of crimpers. Scroll down the page to "using Headlight relays for photos of the crimps.... http://www.cibolas7.net/30105.html
Sorry this is long, but I always wondered what everyone meant by "ratcheting crimpers" in all the car forums, so I thought I would explain it fully now that I know.
djbigskrilla
Sep 20, 2022 01:04 AM
Oct 5, 2015 06:07 PM
MusicCity615
Sep 27, 2015 12:53 AM
Sep 3, 2015 07:14 PM
ccwebb
Aug 11, 2015 06:47 PM
