engine gurus
Old Sep 19, 2009 | 09:08 PM
  #21
67mustang302's Avatar
67mustang302
I'm running flat tops with 5cc reliefs, 4.100" bore gasket with .039 compressed, 4.04 bore with a 3" stroke and the piston is .006" below the deck, and with a 60cc chamber my compression is only about 9.44:1 If it were 0 decked then it would only be about 9.6:1 and with 0 deck and a 58cc chamber it's still only 9.8:1.
Old Sep 19, 2009 | 09:12 PM
  #22
cprstreetmachines's Avatar
cprstreetmachines
Originally Posted by 67mustang302
What compression you tolerate on pump gas has a lot to do with the cam, intake and head selection.
And don't lower compression by using thicker gaskets, it just makes the problem worse. Yeah, you might lower compression by a half a point, but you reduce quench effectiveness which reduces detonation resistance.
DAMN good advice !!
Old Sep 20, 2009 | 03:28 PM
  #23
eZ's Avatar
eZ
Ive been reading up on quench effectiveness. Looks like running the thicker gasket has the adverse effect to detonation just as 67mustang302 had stated. Had no idea it was so important. Im going to run the 10.8 since the cam was specifically designed for it. If I run into a problem ill address it then. should be fun spinnin it up to 6800 though =)
Old Sep 20, 2009 | 03:48 PM
  #24
Starfury's Avatar
Starfury
I bet. I wind mine up to 6200 regularly. It's an awesome, ungodly sound
Old Sep 21, 2009 | 05:12 AM
  #25
kalli's Avatar
kalli
it sounds scary alright :-) i wonder if it frightens people when you pass them like that.
I'd be ...
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
