sill plate installation problem
Old Sep 28, 2009 | 09:20 AM
blue289's Avatar
blue289
Default sill plate installation problem
I bought new sill plates and the screw holes for the screws that go through the carpet and into the body do not line up. Has anyone had any issues with this? There are slits that the screws fit into on the body but they are too close to the door. I started damaging the plate when I tried to install them.
Old Sep 28, 2009 | 09:56 AM
tx65coupe's Avatar
tx65coupe
I have found that the new door sill plates usually require some persuasion to fit.
Old Sep 28, 2009 | 12:31 PM
zmetalmilitia's Avatar
zmetalmilitia
As do most repro pieces. I hate that. I wish they would fit better. Overlay the two plates and see how far they are off, maybe it can be rigged somehow.
Old Sep 28, 2009 | 12:56 PM
blue289's Avatar
blue289
should I try to drill new holes that do line up?
Old Sep 28, 2009 | 02:01 PM
zmetalmilitia
That's about the only solution I know of, unless you drill new holes in the car to align the new sill plate. Either way, it is a sucky job. I always hate drilling or cutting on my car to make something fit. Why can't they make stuff to align up?
Old Sep 28, 2009 | 03:53 PM
boogerschnot's Avatar
boogerschnot
Are you sure that your body guy didnt cover your old holes?
My holes lined up just fine on both sides. Are you sure you have the sills with the correct side pointing out towards the door?
Old Sep 29, 2009 | 02:29 AM
tx65coupe's Avatar
tx65coupe
You shouldn't have to drill new holes. I meant that you may have to try to form the sill plate a little so that it will fit.
Old Sep 29, 2009 | 03:42 AM
MetalEd's Avatar
MetalEd
I don't know your sill plates and it shouldn't matter, but are the holes identical? Is it possible there is a left sill plate and a right sill plate and the holes will not line up if they are not on the correct side of the car (I don't know why this would be, but maybe some over-sized/undersized, specialty plate or something?) It wouldn't hurt to try each plate on both sides of the car...
Do they make them for different years and they may be for modern Mustangs?
just tossing some possibilities out there.
Old Sep 29, 2009 | 03:47 AM
tx65coupe's Avatar
tx65coupe
I guess we should have established which sill plates you have. Do you have reproduction OEM style ones, or the lighted ones, or some other universal type?
Old Sep 29, 2009 | 07:32 AM
blue289's Avatar
blue289
I bought the cheap aluminum sill plates from Mustangs Unlimited. They both are identical and match the ones I took off the car.
