Cam ?
Old Oct 17, 2009 | 04:52 PM
Flash70's Avatar
Flash70
Default Cam ?
Okay so in my last thread I got some good feedback about my shaky starts. I adjusted the carb a little and it injects better. Now I need to get my plugs to fire in the correct order. I am not sure if the machine shop put in a mod cam or stock cam. I heard the mod is a 351 firing order and the stock is 302. How do I determine this without taking apart the engine? Would taking off 1 valve cover and watching for them to pop up work? Like crank it manually and write down the order it goes in. Then after I do that set it to tdc or around there considering I do not have any timing marks, they were painted over, and then try and start the engine??
Thanks again guys. Huge help.
Flash
Old Oct 18, 2009 | 09:00 AM
hotrod351's Avatar
hotrod351
removing the valve cover would be the only way seeing as you dont know if they put a 351 cam. but i didnt know they could swap a different firing order cam. as for painted over timing marks, get a piece of sand paper and sand it off.
Old Oct 18, 2009 | 11:25 AM
Stepman's Avatar
Stepman
That's the way to do it. Watch for the intakes to open. Didn't know your marks were painted over. I thought they were MIA. I would take a pocket screwdriver and scratch the paint off the marks (it just shows up better)
Old Oct 18, 2009 | 12:54 PM
Flash70's Avatar
Flash70
Yes I thought they were MIA as well but the shop said they probably just painted over them. So I need to look for them now... Doesn't putting in a new cam change the firing order?? That is what I thought. For instance if it is a 351 cam wouldn't the engine have a 351 firing order? Like firing order dependent on cam?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
